Driver side vent
Driver side vent
The screws holding the vent cover are frozen .I have sprayed with auto trams fluid / acetone mix . It mounts emergency brake mount . Seems to be too much flex for a hand driven impact driver .
Should I go after the screws with a Dremel cut off or is there a better method ?
On my '77 F100 the air vent gets fresh air from the cowl vent. Would think yours is the same. I have that whole thing in pieces now. Don't think there's any way to reach the screws from the back side. Not sure what you mean about the emergency brake being part of it. Maybe I'm missing something. You do mean the sliding vent on the kick panel?
I'd drill the screw heads off, then when you get the vent off you should be able to grab em with vice grips.
My mistake . Emergency brake pedal is in the way .i can't see how to access it except from the inside .I am going to try a Dremel on the inside . Leaves , debris , rust , and who knows what else I will find in there . I have two freshly painted fenders ,but I am not at that stage yet . It is a daily driver .
codafisler
04-18-2012 08:05 AM
AK Fifty-Three
02-19-2006 10:15 AM
Franken-Truck
04-25-2005 09:16 AM
