58 volt ficm
Old 03-25-2013 | 11:47 AM
dauntejoel's Avatar
dauntejoel
58 volt ficm
I was gunna get my ficm rebuilt to the 58 volt option but I was wondering if I could do that with the truck being stock besides an egr delete. Would it blow head gaskets or be hard the injectors
Old 03-25-2013 | 11:54 AM
mustang_309's Avatar
mustang_309
The higher voltage generates more heat in the FICM and is not a good idea, you would be better served going with Ed at FICMrepair.com
Old 03-25-2013 | 12:18 PM
dauntejoel's Avatar
dauntejoel
Wats the eco tune or atlas tune on the ficmrepair intake form
Old 03-25-2013 | 12:34 PM
f-350 turbo's Avatar
f-350 turbo
Better much throttle response from takeoff =
Old 03-25-2013 | 12:42 PM
mustang_309
I have the atlas 40 and love it. X2 on better throttle response.
Old 03-25-2013 | 02:54 PM
dauntejoel's Avatar
dauntejoel
Is the eco tune or the atlas 40 tune better.
Old 03-25-2013 | 02:59 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Which is better - Camels or Lucky Strike?
You want better mileage or better performance?
Old 03-25-2013 | 03:59 PM
dauntejoel's Avatar
dauntejoel
If it wouldn't blow head gaskets I'd want which ever is performance.
Old 03-25-2013 | 04:34 PM
MC5C's Avatar
MC5C
You have to define performance, it means different things to different people. What does it mean to you?
Old 03-25-2013 | 04:35 PM
npccpartsman's Avatar
npccpartsman
Typically the higher performance tuning gives the best fuel mileage because it's also more efficient BUT your right foot has to show some restraint. I'd go with the Atlas 40 tune and the upgraded FICM from Ed. You absolutely can't go wrong there.
Old 03-25-2013 | 07:59 PM
dauntejoel's Avatar
dauntejoel
I want faster acceleration but I don't want a lot of black smoke and be a diesel driver that is frowned upon.
Old 03-25-2013 | 08:41 PM
the_auto_tech's Avatar
the_auto_tech
If you're ever gonna tow, get the Atlas 40. Hercules without a doubt is not a tow setup and even unloaded using an SCT will require you to watch the pyrometer VERY closely to prevent the EGT's getting too high. Atlas 80 might work to tow if you're not gonna tow heavy, but if you're gonna tow above 8,000 pounds then don't get it either. Also, if you take into account the fact that you only get about 25% of the advertised power when using the SCT tuner then it makes sense to just use the Atlas 40 anyways. You COULD get the Gryphon FICM tuner, but for another 250 dollars its not worth it to me. You're namely just wanting the throttle response and MPG increase form the FICM tune, not power. Use the SCT tuner for power.
Old 03-25-2013 | 09:53 PM
f-350 turbo
But if you need gauges for the factory PID's the Gryphon does that too. I think it's a fair deal.
Old 03-25-2013 | 09:56 PM
f-350 turbo
I would take a guess and say 95% of the people get the Atlas 40. I did not notice any black smoke, just quicker out of the hole.
Old 03-26-2013 | 11:08 PM
the_auto_tech
I guess, but just for using it to switch between FICM tunes I don't feel a point for 250 dollars. Also, the rollback costs more money on top of that too. There's so little to gain between FICM tunes when you're using a PCM programmer most people can't justify it.
Quick Reply: 58 volt ficm
