How does it idle? Also you can unplug the ICP sensor (it is located at the front of the passenger side valve cover, sticking straight out of the valve cover) at idle and see if how it runs changes
It is the black cylinder that has two metal lines running to it and the ICP sensor connection comes out towards the exterior of the truck? Or is that something for the AC? Idles rough sometimes and then other times perfect.
Everything is stock a far as I know. Haven't had the time/money to do a lot of extras. Thanks for the pic. Going to try it now. I will let you know after its done.
I use WIX or motorcraft quality and above. I don't go cheap on anything because I want to keep this truck for a long time.
Not trying to bust your chops or anything but the only filters you should be running are motorcraft/racor oil and fuel filters and motorcraft air filters, the reason it is ok to run the racor filters is because they make the filters for motorcraft. Here is a youtube video that explains some of the differences,
Oh wow, i somehow mixed up two threads with similar problems, thought you had a 2005. On our 2003s, the ICP sensor is behind the turbo. This is a little more challenging, and i wouldnt go crawling back there just to unplug it
OK just went and picked up the ScanGauge II. I guess I can wait until tomorrow for your help but I am going to plug it in and at least do the set up part in the quick guide.
Ok some results for ya. I started her up and it gave me cold idle. Then I drove it around a bit and warmed the engine up and got the hot idle. Let me know what you think and hopefully it isn't horrible news.
Values look pretty good. Did the scangauge give you any codes? Sometimes they aren't the best at reading codes on these...do you have a buddy with an SCT tuner? Or some type of computer car scanning program
It gave me no codes... And I don't know anyone with an SCT tuner. Should I have bought one of those instead of this thing? They had one for sale at AutoZone for nearly 300 or something....
