1977 F250 Highboy restoration
Hi Jep,
The other guys can give you a lot more information but from my experience it is fairly straight forward to make your change. For my '78 F250 I swapped out my old 400m with a 429. I would suggest looking to L&L (www.landlproducts.com)
for motor mounts, they worked really well for me. Good luck and get us some pictures of your build.
There were TWO other types of dealer installed A/C offered for these vehicles.
There is no supplier that I know of for frame crossmembers, but you could always make your own. Aftermarket body panels are not as thick as original and fit is a hit or miss. If you want quality original tooling body parts go with Dennis Carpenter or much cheaper, find rust free used ones. A new OEM front fender is like $400 from DC. Repair panels are not as thick either, but they work OK for repairs.
restore
Hey Jep grind the rivets out remove cross member.grind the rust off ,if need repairs ,find a local small welding shop and have them repaired,keep your eyes out for old dents in backyards or back woods,alot times they will give you the stuff,dont be afraid to ask.I have a long list of parts that were there for the taking,take your time ,it takes time,In the end each piece has a story.
I like lmc but it isn't as good as the stock parts
Yes on the cab but you will need to change out the mound in the middle with a 4x4 one or cut the one on it for the transfer case . The 460 is more power and toque for towing and pulling less mpgs all around is all I know about them Ac is a add on from the factory isn't really worth the money it only kind works I have the system laying in my shop floor because it was just in the way and only worked in temps up to 90 then it just heated up the motor with no cold air
Hey Tinstar in your opinion upgrading the 351M to a 460 w AC is not worth the effort for the reason it doesn't really cool the cab down in hot whether. I can see where it takes valuable space under the hood. Should I build without it. Does it cause worse MPG what is the best that I can expect when completed.
