Blue Spring Kit Causes Pressure Drop !!?
Old 01-15-2013 | 05:59 PM
tperk100's Avatar
tperk100
Just installed blue spring kit. Looked pretty straightforward, but apparently I have done something wrong. My fuel pressure was 45 without the kit and is now 25-30. Started and ran vehicle for only about 5 minutes. Seems to run OK....at least at fast idle.
Any ideas on what's going on?
Thanks
Old 01-15-2013 | 06:50 PM
UGA33's Avatar
UGA33
Did you pinch or bend the spring on install?
Old 01-15-2013 | 06:53 PM
tperk100's Avatar
tperk100
Not that I know of, but I am thinking I am going to have to take it apart again to check for something like that.
Old 01-15-2013 | 06:58 PM
UGA33's Avatar
UGA33
It can be very easy to do if you don't put even forward pressure going back together with the cover. I actually goofed one up and had 90psi worth of fuel pressure.
Old 01-15-2013 | 07:46 PM
daddykitty's Avatar
daddykitty
just dont over tighten those bolts on the cover they strip really easy
Old 01-15-2013 | 08:46 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
And re-installed that brass bushing the backs the spring too?
Josh
Old 01-18-2013 | 02:20 PM
tperk100's Avatar
tperk100
I know this sounds crazy, but I noticed whenever I drove that the pressure was increasing slightly. After 3 days and about 30 miles the pressure is holding at 58 !!!
Old 01-18-2013 | 04:27 PM
mustang_309's Avatar
mustang_309
Perhaps you just had some air in the connection to your gauge.
Old 01-18-2013 | 04:31 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Ford includes a "fixes itself" mod now!!!! Standard equipment. LOL
WH 6.0
08-06-2012 09:05 PM
95PSDieselP
04-20-2012 11:13 AM
Randy777
09-01-2011 06:55 AM
Visseroth
04-30-2011 12:12 AM
Strokin-8
10-18-2010 01:38 PM
Quick Reply: Blue Spring Kit Causes Pressure Drop !!?
