Changing the seals on a C6?
Old 12-22-2012 | 11:26 PM
JRB65's Avatar
JRB65
My Tranny is leaking like crazy... Its a 1974 C6 (2 Wheel Drive) behind a 360FE. How hard is it to change the front and rear seals on the tranny? Do you need any special tools? Ive never pulled a Ford Tranny so I just want to see what Im up against before I start down that path... It shifts great but just leaks like crazy.
JRB65
Old 12-23-2012 | 01:48 AM
mikeo0o0o0's Avatar
mikeo0o0o0
No special tools required, but to change the front seals you'll need to drop the transmission.
If you do drop the trans. don't replace just the torque converter seal (p/n C2AZ-7A248-A) also replace the pump seal (C6AZ-7A248-A) and the pump to housing gasket (C6AZ-7A136-A).
Old 12-23-2012 | 04:13 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Extension housing seal is D5AZ-7052-A (replaced C3AZ-7052-A).
Parts catalog refers to both 7A248 seals as front pump seals. C6AZ-7A248-A is actually an o-ring (9 1/2" I.D. x 10 5/16" O.D.).
Old 12-23-2012 | 09:28 AM
OldStyle's Avatar
OldStyle
Rusty Roller
That's because if you pull the pump with the trans horizontal the clutch plates inside will drop and you can't reinstall unless the transmission is in a vertical position.
JRB65
02-01-2013 10:53 AM
Animal28
11-04-2012 07:48 AM
BadDogKuzz
26
02-09-2011 09:13 AM
76CamperSpecial
01-12-2010 03:04 PM
RP27G8G
05-18-2007 08:10 AM
Quick Reply: Changing the seals on a C6?
