ScanGauge II denier
Old 12-10-2012 | 07:44 PM
BLADE35's Avatar
BLADE35
Originally Posted by DieselVol
I think the coolant is now green, but I'll have to check that out (been pouring here for 2 days and I can't get it in the garage). If it comes to it, is the water pump and/or oil cooler a "do it yourself" job?
Well Lots of Guys here have Done those things
You better research it and decide if its something you want to tackle
Iv seen a Few Guys have to Tow there truck and haul a Box of Parts to the Mechanic
IDK your Skill set so ??????????????
I will help you as much as Possible over the internet Granted thats Not Much But if you lived by me I come and wrench with ya Im in utah. Not shure where you are at but there are some great folks here on FTE that will also help Folks out
WATERPUMP CHANGEOUT THREAD
https://www.ford-trucks.com/forums/8...pump-info.html
OIL COOLER REPAIR INFO
https://www.ford-trucks.com/ford-manu...%20Removal.pdf
https://www.ford-trucks.com/ford-manu...%20removal.pdf
https://www.ford-trucks.com/ford-manu...Oil_Change.pdf
https://www.ford-trucks.com/ford-manu...er_Removal.pdf
  #77
Old 12-10-2012 | 07:46 PM
DieselVol's Avatar
DieselVol
Is there a "how to change out an oil cooler" thread somewhere? I'm not ready to change it, but it appears I'll need to get down to it to do the reverse flush of the oil cooler, and am curious as to what all has to come off to get there.
  #78
Old 12-10-2012 | 07:48 PM
DieselVol's Avatar
DieselVol
Funny! Looks like we were typing at the same time. I'll look it over. Skill set is iffy, time is the major problem. Dang coolant is green.
  #79
Old 12-10-2012 | 08:02 PM
BLADE35's Avatar
BLADE35
That Sucks the More you drive it the More the Green Coolant is going to Slim the system
Atleast the EGR Cooler is gone wont make coolant slime as fast
COOLANT FLUSH
click the star
  #80
Old 12-10-2012 | 08:33 PM
DieselVol's Avatar
DieselVol
COOLANT FLUSH
click the star
Dude, you're some kind of website savant! Pretty cool with the star thing. I read over that yesterday, but it really doesn't show how to get down to where you start with the reverse flush. I've got to start at the starting place.
  #81
Old 12-10-2012 | 08:43 PM
BLADE35's Avatar
BLADE35
LOL it just did the star thing I need to figure out how to Label it what I want
here is where to reverse flush at the Orange hose there is a Cover plate with a couple torx screws you take off
heres a Pic
Amdriven (Sean) Has a Better Pic of it
  #82
Old 12-10-2012 | 08:53 PM
DieselVol's Avatar
DieselVol
Yeah, that picture answered a lot of questions, but mainly proved I ain't got time for all that take down. Can that port for the reverse flush be accessed without all that takedown, or is all that going to be necessary? Recall, I have no EGR.
By the way, I was digging around in there tonight and found a snap on connector with nothing on it that came from the general area of where the EGR was. Think that might the EGR valve connector?
  #83
Old 12-10-2012 | 09:02 PM
BLADE35's Avatar
BLADE35
here some more Pics
Yes you can get to it without all that teardown I beleive
These were taken during an Oil Cooler Job
More Pics
https://www.ford-trucks.com/forums/members/blade35-albums.html
  #84
Old 12-10-2012 | 09:07 PM
BLADE35's Avatar
BLADE35
does it look like this????
its the EGR Pigtail
  #85
Old 12-10-2012 | 09:12 PM
DieselVol's Avatar
DieselVol
its the EGR Pigtail
Yes, I believe that's it! I'll re-eyeball it tomorrow. Now, am I just buying a new EGR and plugging it in, or an I taking that plate they put over the opening and actually reinstalling it? Also, Matt wrote my tunes for no EGR. Do I need a rewrite now?
  #86
Old 12-10-2012 | 09:17 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Yes, you can reach that port. You will need to create some sort of plug to put the hose into the port. There was a guy that was doing a lot of flushing to reduce his temps.
part #s for new o-rings and hose if you need it too.
Coolant hose for egr cooler - 4C4Z-8592-AA
Inner O-ring for outlet port - 3C3Z-9N693-FA
Outer O-ring for outlet port - 3C3Z-9N693-EA
Anyway, here is a photo of the port to access.
See that one torx bolt just under the edge of the turbo? You will need a short wrench to get that out. One person epoxied the torx bit into a little wrench. Might want to stick some small rags around the open areas where little torx bits can fall. You may not get them back until you need to remove, let say a turbo!!! I got 2 of mine back at that point! Pull off the CAC tube.
  #87
Old 12-10-2012 | 09:31 PM
BLADE35's Avatar
BLADE35
Maybe you can get a EGR Valve from the Salvage yarrd
some use the Blocker plate then lay the egr valve in there and zip tye it
Mine is Deleated (Cooler is GONE)but the EGR Valve is Instaled in its Bore and plugged in this way it Looks closer to stock
As far as the Tunes as far as I know all the tune does is Keep the CEL Off ypou might want to take that up with Matt
  #88
Old 12-10-2012 | 09:35 PM
DieselVol's Avatar
DieselVol
I will ask Matt and get back to you. I ought to provide something besides questions here.
  #89
Old 12-10-2012 | 10:46 PM
DieselVol's Avatar
DieselVol
Matt reports that he always prefers to leave the EGR valve in and that all of his programs are written for it to be in place. He said I will not need a rewrite. My plan now is to get an EGR back on it and see if that affects the fan and cools it off. If so, I'll just get the green coolant out and let it run. If not, wash out time.
  #90
Old 12-10-2012 | 11:03 PM
DieselVol's Avatar
DieselVol
Quick Reply: ScanGauge II denier
