here goes my Supercab Build
Old 11-02-2012 | 06:28 PM
hasteranger's Avatar
hasteranger
Originally Posted by crazyredneckanyhow
Ive used a few of these kits and the quality is top notch. Use the coupon code pbb10 for 10% off. It flips the ubolts upwards so nothing is hanging below the axle.
didn't see the link, you talking about these:
Ford Dana 60 Ubolt Plate (Front, Early) - RuffStuff Specialties
  #47
Old 11-03-2012 | 01:43 PM
darkpurp1e's Avatar
darkpurp1e
im happy with the way it came out, id rather have extra strength than cut out an entire cross member when i dont have to, i finished the welding, and its painted up. i dont have a pic of the final product of x members but the engine is bolted in with no clearance issues. except for the p/s pump to box, and the steering shaft to manifold. uh oh. will post pics later
  #48
Old 11-03-2012 | 08:49 PM
monster67's Avatar
monster67
Truck is coming along nicely, im looking forward to seeing the final product, keep up the good work
  #49
Old 11-04-2012 | 08:04 PM
darkpurp1e's Avatar
darkpurp1e
engine is in and on new xmember nicely. all measuring went very well and its sitting exactly where i want it.
and sorry ford i really didnt like the way you set this up for me...
  #50
Old 11-23-2012 | 03:33 PM
darkpurp1e's Avatar
darkpurp1e
Update: sorry ive been busy with the new job and such no time to update, theres more pictures also to add. im looking for serpintine belt double sided 5 ribbed for the set up im trying to run, or if anyone knows a smooth pully for the water pump either one would work let me know if you have ideas, ill post a pic of that later, also rebuilt front axle pics coming. anyways this is whats been done lately,
minor transmission cut and fits like a glove
lined the old drive shafts up and looks like theyll work after a new carrier bearing for the rear and u joints
making linkage for the 205 setup
convinced my dad to trade his 60 for a 44 for half profit, anybody local needs a 60 front with 3.54 ratio its for sale
  #51
Old 11-23-2012 | 06:01 PM
crazyredneckanyhow's Avatar
crazyredneckanyhow
Where is local to you?
  #52
Old 01-22-2013 | 06:23 PM
darkpurp1e's Avatar
darkpurp1e
sorry i havent updated this in a long time, much progress
the yard
behind front seat on cab crossmember rot
new metal in all vents and top of firewall, it was rotted through leaking inside the cab oh and a sneak on the tires that im going to hate
drivers floor
p/s floor/ rocker work
two new cab mounts and front painted
drilled holes for body bushings
and the cabs back on
next step im modifying a 14 bolt to fit with disk brakes (with e brakes) in the rear, ill be doin cab corners at some point also. more to come and will probably be another couple months before another update
  #53
Old 01-22-2013 | 06:26 PM
darkpurp1e's Avatar
darkpurp1e
oh and if your wondering we set up a bench seat right in front of the gas tank on top of the frame thats why your seeing feet there
  #54
Old 01-22-2013 | 11:08 PM
Aussie_F_trucker's Avatar
Aussie_F_trucker
Looking good. That bronco woulda been an interesting piece of gear if it was done right though
  #55
Old 02-04-2013 | 09:50 PM
BIGS003's Avatar
BIGS003
Im digging the project. I have similar plans for my 78 super c.
I was worried about frame strength. I was considering fish plating the outside of the frame a ft or two with the motor mounts towards the middle.
It might not be needed. i know the 7.3 is a few 100 lbs heavier. might not be a big deal, i just know my truck has been airborn before
  #56
Old 03-11-2013 | 10:29 AM
darkpurp1e's Avatar
darkpurp1e
Hey everyone sorry I haven been updating but the truck has come a long way. Listen I was wondering if anyone knows where I can find 4 inch lift springs for the rear. I'm doing a swap one ton 14 bolt and I don't want to keep the junk factory springs so I was going to take factory block out and get 4 inch springs? Anyone have a link I'm having trouble finding just the rear springs. Ill add some pics soon
  #57
Old 03-11-2013 | 08:23 PM
crazyredneckanyhow
For ride and comfort grab a set of springs off a newer 1 ton chevy and do a shackle flip.
  #58
Old 03-12-2013 | 08:55 AM
Luch's Avatar
Luch
What did you ever do about that rust/corrosion over the passenger side door on the roof? I have the SAME thing on my truck and it's surprised me too...
  #59
Old 03-12-2013 | 03:21 PM
hoffy's Avatar
hoffy
gonna be a nice truck. i did super cab 4x4 build the rust repair nightmares still wake me up at night. just keep on keepin on
  #60
Old 08-22-2013 | 11:41 AM
darkpurp1e's Avatar
darkpurp1e
sorry time to updat like 6 months later
my gm 14 bolt
my buddy was doin the same thing in his 84 k20... his perches didnt line up
hydro booster mouted up
started takling this i saw someone was wondering about it.
used a piece out of a old roof
Quick Reply: here goes my Supercab Build
