Can't get the brakes to bite
Old 07-25-2012 | 09:10 AM
daningraham's Avatar
daningraham
So here is the set up that I have in my '74:
'78 Dana 60's front and back with dual caliper discs on the front and a disc conversion on the rear.
Willwood P-Valve for the rears (removed factory block).
All new lines front to rear.
New '78 M/C with a '78 F350 dual diaphram booster.
EBC 6000 series Green pads.
I bled the M/C twice before I put it in and have bled the system several times after installation and still cannot seem to get a hard hit on the system when I push the pedal down. I have a good inch or two of travel in the pedal which I also feel is a little excessive.
One other wierd thing I have noticed over time is that it appears that the small reservoir is loosing fluid as the level drops and the level in the large reservoir rises. Not sure how that is possible.
Anyone have any suggestions on how to get this thing to make me feel more confident about it's abilitly to stop? I would expect that this thing would stop on a dime if I wanted it to. I only have 33's on it so I can't see where tire size is a problem.
Old 07-25-2012 | 09:11 AM
MisterCMK's Avatar
MisterCMK
Silly question but are your bleeders on the top or bottom side of the caliper?
Old 07-25-2012 | 09:28 AM
daningraham
They are on the top front and back.
Old 07-25-2012 | 12:47 PM
bamaf150's Avatar
bamaf150
Another stupid question; have you properly adjusted the rears ie; tighten the adjusters until the wheels LOCK then back off evenly until they lightly drag?
EDIT: disregard, I see you have discs in the rear, I should really slow down a bit when reading lol
Old 07-25-2012 | 01:31 PM
montana_highboy's Avatar
montana_highboy
Here's a nice tech write-up that may be of some assistance...
Pirate4x4.Com - The largest off roading and 4x4 website in the world.
Old 07-25-2012 | 07:39 PM
wrightme43's Avatar
wrightme43
How are you bleeding? Pressure bleeder, vacuum bleeder, gravity, or hand? Are you being very gentle if bleeding by hand? Fluid cavitation can hold and trap air in the system.
Are your caliper slides free and properly lubricated? I.E. can you push the piston back in its bore, and freely and easily slide the calipers back and forth?
Is your master cyl a disc/disc or a disc/drum?
Any of these things can cause the problem you describe. My all time favorite though was the girl that came in and said her dad just did her brakes a few weeks ago!!!!!! and it wouldnt stop and made a horrible grinding noise. He had installed the metal backing plate as the stopping material. After the new rotors were machined, and the pads replaced, she decided to just not let him do anymore work on her car.
Old 07-26-2012 | 09:35 AM
daningraham
I have a feeling that the issue with the master cylinder losing fluid from one chamber and filling the other may be the source of the problem. All the components are new and working correctly. I have bled the system by pressure and by vacuum and neither made a difference.
The M/C is under warranty so I will have them swap it out and go from there.
SteveJH
04-22-2018 08:29 PM
SNAFU_Bill
18
02-19-2010 03:47 PM
ncl
01-30-2007 05:32 PM
zsir
11-23-2003 05:36 PM
Quick Reply: Can't get the brakes to bite
