400 fuel pump
Old 07-22-2012 | 05:25 PM
Schickel's Avatar
Schickel
400 fuel pump
I recently put a new intake and a 650cfm holly carb on my truck and now my engine is starving for feul. Is there a manufacturer that makes larger capacity pumps or can i turn up an origonal one to compensate for the larger carb?
Old 07-22-2012 | 05:36 PM
J ballan's Avatar
J ballan
I would put a gauge in before the carb and just verify what the fuel pressure is. From what I've heard a good stock pump should put out more than enough pressure.
Old 07-22-2012 | 05:49 PM
Schickel's Avatar
Schickel
What should i have for pressure?
Old 07-22-2012 | 08:05 PM
J ballan's Avatar
J ballan
I believe it should be around 6.5 to 8 psi.
Old 07-22-2012 | 08:26 PM
704 dentside man's Avatar
704 dentside man
An intake and carb wouldn't relegate a, what was good fuel pump, now useless. My guess would be an improperly tuned new carb.
Old 07-22-2012 | 08:33 PM
devino246's Avatar
devino246
Are you positive it's starving for fuel and not flooding? The stock mechanical fuel pumps often output too much pressure for aftermarket carbs.
Old 07-22-2012 | 08:44 PM
Schickel's Avatar
Schickel
Well it happens after ive been goin down the road for a while if i pump the gas or pull the choke it tries to keep running and i have a clear filter right before the carb that is almost empty when i get out and look at it
Old 07-22-2012 | 08:51 PM
Blue and White's Avatar
Blue and White
A sneaky cause of fuel starvation is collapsing or leaky rubber fuel lines. They get old and soft and the fuel pump sucks them shut... or they leak a little air on the suction side and the pump pulls air. Worth checking/replacing all the short sections of rubber line.
Old 07-22-2012 | 08:52 PM
J ballan's Avatar
J ballan
How long is a while? Could be vapor lock maybe.
Old 07-22-2012 | 09:26 PM
Schickel's Avatar
Schickel
After around three miles but then if i let it sit for like twenty min itll start right up
hail destroyer
09-15-2016 01:18 AM
Rmc292
10-30-2013 01:43 PM
mr_ranger-79
01-21-2011 05:46 PM
gbroehl1
02-01-2007 01:32 PM
bored-68-ford
10-26-2004 08:52 PM
Quick Reply: 400 fuel pump
