Steering column wiring... what is this thing?
Old 11-07-2021 | 11:11 AM
shorod's Avatar
shorod
Oh yeah, that does look suspicious! Good job finding that! At least you didn't yet replace the key cylinder switch and ignition switch.
-Rod
  #32
Old 11-07-2021 | 11:14 AM
justain's Avatar
justain
no worries thanks for your help. I dunno how I didn’t see that broken wire the first time I went under there. Hopefully this fixes everything and I can be on my way home 😭
Originally Posted by shorod
I'm sanding and painting my deck this morning so there may be some significant gaps between when I respond and when I check for updates.
-Rod
  #33
Old 11-07-2021 | 06:55 PM
justain's Avatar
justain
starter changed now it sounds like it wants to start but also sounds like a dead battery. Terminals are tight as can be. Possible need shims to make is more tight.
battery is good.
  #34
Old 11-07-2021 | 07:44 PM
justain's Avatar
justain
battery is good.
-Rod
edisonranger
09-13-2021 02:59 PM
thewheelman
11-08-2016 08:49 PM
Oldanvilyoungsmith
09-27-2016 10:30 AM
sawtooth
1999 to 2016 Super Duty
22
05-19-2009 11:01 AM
BuickTurbo
1997 - 2003 F150
01-18-2007 04:08 PM
Quick Reply: Steering column wiring... what is this thing?
