'05+ Super Duty Coil Springs on 2WD IDI
Old 05-10-2012 | 09:42 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
has any body ever put '05+ superduty coils on a 2wd idi or even 2wd obs psd?
i found this link in a thread on OBN.
would it be a direct spring swap? is it necessary to remove the front sway bar?
thanks
Old 05-11-2012 | 01:57 AM
91dirtydiesel's Avatar
91dirtydiesel
You want to lift your truck? Or what? Seems pretty straight forwards...at least they made it sound that way
Old 05-11-2012 | 06:23 AM
'94IDITurbo7.3
i don't want to "lift" it. just wondering if it would be an option when/if my coils where out. leveling the front out would be awesome as well.
Old 03-30-2015 | 03:14 PM
Whatsinthebox's Avatar
Whatsinthebox
Did you ever find out if the excursion coils are direct swap or not? I currently have 6 inch lift springs meant for a gas f250 that sags bad and has caused over a degree of negative camber...
thanks
hwybee22
11-29-2016 09:02 PM
Willl
02-06-2016 06:50 PM
madd91
12-18-2011 07:46 PM
Misky6.0
06-13-2011 10:31 AM
Ubbzy
1999 to 2016 Super Duty
11-29-2010 05:42 PM
