Door keypad use sounds alarm???
I bought a 2008 F250 crew cab, long box diesel and other than a couple of minor issues I love it. Tows my race trailer like it isn't even there.
If I use the remote to unlock the doors then everything works as it should, no alarm.
If I unlock the doors using the key pad the alarm sounds?
Has anyone had this problem and what did you do to fix it? I have read thru many of the threads I can find but most are reprogramming the keypad. I am suspecting that a door open switch may be the culprit but wouldn't that affect the remote as well?
Unless the door key pad is reprogrammed to the frequency of the after-market alarm, the alarm will sense the keypad entry as an unauthorized entry and is just doing its job. My 2007 does the same thing. I have a Viper alarm and use it mostly, but at the deer camp and around the house, I use the keypad. Also when fueling and leaving the engine running, it's convenient to lock and unlock with the keypad.
If it was an aftermarket alarm I would have thought I should be able to lock the truck using the keypad and unlock it using the keypad without the alarm sounding (but it does) as I am not arming the alarm with the key fob.
pmyers, did you ever solve the alarm/keypad issue? I am experiencing the exact issue. Recently purchased 2004 F150 Lariat, 137K miles, great shape. Everything on the truck looks and works perfectly, except... If I use the remote to unlock the doors, everything works as it should, no alarm.
If I attempt to unlock the doors using the keypad, the alarm sounds as soon as I touch the keypad.
I replaced one of the keyfobs a couple weeks ago, and both the new one, and the remaining original continue to work fine. I've checked under the dash, and there appears to be a KARR 4040a alarm installed. No documentation on the KARR, but online search indicates this was probably installed at the dealer upon initial purchase.
I just want to be able to use the keypad for entry. Any solutions?? Thanks.
PW01
04-02-2007 11:21 AM
n6nfg
11-12-2004 11:20 AM
