Troubleshooting door ajar switch
Old 04-29-2012 | 02:01 PM
bodabdan's Avatar
bodabdan
Hi guys,
It seems lately that when I wash my truck, I get a door open light on the dash that goes off in a day or two regardless of anything else I do.
I am sure that one of my switches is getting wet and eventually drying out. Does anyone have any troubleshooting tips, schematics, etc. that could save me from having to pull all the door panels to check each individual switch?
Also I am assuming that these switches would be closed when the door is closed and open when the door is opened. I'm hoping that there is a connector somewhere that I can unplug and take some resistance readings to find out who my culprit is.
I guarantee you that if I just start randomly pulling door panels I won't find it until the last one. Thanks in advance for any pointers.
Old 04-29-2012 | 03:37 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Old 04-29-2012 | 03:41 PM
BLADE35's Avatar
BLADE35
Take some WD-40 or something of the like and spray each door Lock Mechanism in the Edge of the Door
Spray it open close a few times spray again basicaly work the Lube into the Latch
Old 04-29-2012 | 03:49 PM
BLADE35's Avatar
BLADE35
Originally Posted by Rusty Axlerod
Looks like we was thinking the same thing Rusty
Old 04-29-2012 | 04:45 PM
Rusty Axlerod
Yup , I haven't had a problem with 'em yet but looks like a a few folks have. Looks like $20 will get ya a new switch, 30min to change it out, but I'm with the OP about how to figure which one to change? (IF spraying don't fix it)
Old 04-29-2012 | 07:12 PM
bismic's Avatar
bismic
Wash half the truck - see if it does it again. then switch. If that doesn't work, then heads for driver's side and tails for passenger's
Old 04-29-2012 | 07:40 PM
69cj's Avatar
69cj
Any way we can make this a drinking game?? LOL.
Old 04-29-2012 | 07:45 PM
Rusty Axlerod
Not a "half bad" idea. Lol
Old 04-29-2012 | 09:29 PM
BLADE35's Avatar
BLADE35
FWIW mine was sticking on the Driver Door it gets the Most use so IDK Good Luck
Let us know how you make out
Old 05-02-2012 | 12:14 PM
stinks the truck dog's Avatar
I just changed my door latch because it was locking me out. Switch has been defective since november I was surprised that the door switch is attached to the door latch by a quarter turn. It took me almost 2 hours to change start to finish
Old 05-02-2012 | 06:25 PM
cheezit's Avatar
cheezit
there are door ajar pids if you have a scan tool that will read them
Old 05-02-2012 | 06:42 PM
In my case the left door did not operate the dome light and the right door did. It is not often you can troubleshoot a newer truck without hundreds of dollars for test equipment.
Old 05-03-2012 | 01:28 AM
Yahiko's Avatar
Yahiko
Ok.
I have to ask this. It sort of goes with finding the bad switch.
Guy has a F-250 Diesel. And he also has a pile of ford keys.
Why is it that every time he looks for the key it is always
the last key he uses ?
Answer below.
Because he stops looking when he finds the one that opens the door.
Also if you don't like the mess that WD-40 makes you may want to look for this stuff
it tense to be a bit more $ ACF-50 anti corrosion. One of it's intended uses is for electrical. You should be able to pick it up at most aircraft supply shops or pilot shops.
Sean
Old 05-03-2012 | 05:00 AM
Rusty Axlerod
Wow, too cool. I guess everything is on the data bus these days. How did we ever live without computers.
Old 05-03-2012 | 07:20 PM
cheezit's Avatar
cheezit
we took door panels off alot more. one of the many reasons I hate 7.3's
Quick Reply: Troubleshooting door ajar switch
