determine towing capacity
Old 04-17-2012 | 12:51 PM
abyars111's Avatar
abyars111
How do you determine towing capacity of an older vehicle? For instance if a 72 F250 has a GVW of 6900 lbs with a class III receiver hitch, 3.73 gears, 390 4V and a auto trans. How big a trailer could it pull? 6000#? 8000#?
Thanks for any insight you have.
Old 04-17-2012 | 11:39 PM
MARTYSTOWRIG's Avatar
MARTYSTOWRIG
I do nt have an answer for you. I do have my own thoughts and some advice... 72 is going to be drum brakes and most likely carburated.... Leads me to believe you should stop around 8000 MAAX. always use trailer brakes and you arent going to win any races.
Old 04-18-2012 | 08:54 AM
abyars111's Avatar
abyars111
Thanks. I've got a 3000# trailer now but one day plan to upgrade to something bigger. We are looking at buying an older truck and I wondered what I could pull. I will always use trailer brakes for sure. Any truck I buy will be upgraded to disc brakes. Most of the trucks I'm looking at have a carb with a 390 or 460. I certainly don't plan on buying something that weighs 8000#, a 5000# 24ft will be my max.
Old 04-18-2012 | 09:21 AM
msgtord's Avatar
msgtord
I had a F250 with the optional front disc brakes, and a transplanted 460. The thing was a stump puller for sure.
Old 04-18-2012 | 09:22 AM
jdadamsjr's Avatar
jdadamsjr
Here ya go:
https://www.ford-trucks.com/forums/1...-capacity.html
or here maybe:
https://www.ford-trucks.com/forums/9...-question.html
bottom line you can go to the myford site and see what's there for manuals
Old 04-18-2012 | 10:32 AM
msgtord's Avatar
msgtord
Check out this site.
1972 Ford Memorabilia
hmcfly
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
02-19-2017 08:49 AM
Ex'ed out
05-21-2008 08:52 PM
rfont54
1997 - 2003 F150
01-03-2007 09:18 AM
comertrucks
04-04-2005 06:41 PM
jpeckinp
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
13
01-20-2005 07:59 PM
