1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
01 F350 vibration
Old 04-02-2012 | 10:12 PM
Jfrei's Avatar
Jfrei
01 F350 vibration
I have an 01 F350 crew cab, 4x4, diesel, long box, DRW.
It seems to have a slight vibration under heavy acceleration with a load (15,000 lbs heavy acceleration means 50-75% throttle)
However the vibration is worse while coasting. enough to cause my steering wheel and rear view mirror to vibrate
I do have all new wheel bearings, u joints, and ball joints.
Any idea where I should start?
Thanks you help is appreciated
Old 04-03-2012 | 08:52 AM
redford's Avatar
redford
FTE Leadership Emeritus
Do you have a lift, or is your suspension stock?
Old 04-03-2012 | 07:35 PM
Jfrei's Avatar
Jfrei
All stock, but I found the problem earlier today. Rear section of the drive shaft twisted some how.
Guessing it happened pulling a heavy load. Just finished installing a new drive shaft a little bit ago.
Old 04-03-2012 | 07:39 PM
redford's Avatar
redford
Oh, wow. That must have been one heavy load. WTF are you doing, towing freight trains?
Old 04-03-2012 | 09:30 PM
Jfrei's Avatar
Jfrei
I own a recycling company. The last month I did tow some rather large loads, more then I know I should have. But I had no other options, might be time to get a larger truck.
mrmurph
08-08-2014 02:04 PM
whf
07-27-2010 12:11 PM
4004 F350 dually
10-05-2009 07:55 PM
lance195
11-09-2006 12:26 AM
dremelius
05-05-2003 03:18 PM
Quick Reply: 01 F350 vibration
