front end suspention problem please help!!!!!
Old 03-31-2012 | 09:33 AM
offroadcrazy304's Avatar
offroadcrazy304
I have a problem with the front suspention on my truck and i was wondering if you guys would help me out? well the pasenger side is sagging and so i baught some leaf springs and still does it. whats going on and what can i do to fix it?
thank you for your time
Old 03-31-2012 | 09:37 AM
ReBilld's Avatar
ReBilld
250 or 350?
2wd or 4wd?
lifted or stock?
Old 03-31-2012 | 09:38 AM
offroadcrazy304
Originally Posted by ReBilld
250 or 350?
2wd or 4wd?
lifted or stock?
250, 4wd, stock its a 96 also
Old 03-31-2012 | 09:44 AM
ReBilld's Avatar
ReBilld
Check the ball joints,wheel bearings, spring shackle bushings in the front,and the axle pivot bushings. Also check the axle pivot bracket.
Old 03-31-2012 | 09:48 AM
offroadcrazy304
well i know that my ball joints are bad but i didnt think it would make is sage that low
Old 03-31-2012 | 09:52 AM
ReBilld's Avatar
ReBilld
Oh yeah, bad ball joints can make em sit pretty low sometimes! Especially if the upper and lower are bad. I'd replace the ball joints and then see what you got and go from there
Old 03-31-2012 | 10:17 AM
offroadcrazy304
ok i really appreciate it, thanks and one more question, could i cut my old leaf springs and use them to make a add a leaf?
Old 03-31-2012 | 01:59 PM
ReBilld's Avatar
ReBilld
You can, but I'd just buy an add-a-leaf kit.
Old 03-31-2012 | 02:12 PM
offroadcrazy304
what brand of add aleafs do you perfer? i could get rocky mountain at my auto shop if thats one that you would perfer.
Old 03-31-2012 | 08:01 PM
ReBilld's Avatar
ReBilld
That's probably fine, just make sure it comes with new center bolts and u-bolts and you should be good to go
Wyattdean
08-19-2016 01:49 PM
jjuchems
10-18-2010 11:12 AM
Texasgordo
06-21-2010 07:44 PM
pjwoolw
19
04-20-2009 10:00 PM
buzzchoptop
03-26-2002 06:29 AM
