1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
99 F350 Super Duty Build
Old 09-30-2012 | 08:44 PM
Snowseeker's Avatar
Snowseeker
Originally Posted by Linne
Thank you, that's alot to think about. I do understan the basics, but did not think it was that important.
The funny thing about this is that I did hear from a friend today that in Finland it is illegal to weld on this tie rod so I probably have to cut it loose and only try to bolt it with some type of pipe clamps
It very well could be. It does all kinds of things to the rod when you weld on it from warping to weakening either by making it soft or going the other way and making it to hard and brittle. But it also can be done right, the first step would be finding out what exact metal the rods are made of. Then research the and apply the proper procedure. Almost all the of the time a special procedure is needed heat will be needed. I highly doubt any sort of cooling action would be needed for steering rods but it might be possible.
Or like you mentioned you could just bolt it on. I'm not trying to be a downer or anything, just trying to keep you safe and stuff.
  #32
Old 10-01-2012 | 05:04 PM
Linne's Avatar
Linne
I finally got the steering box tapped today, and it works like a dream, it's almost insane how it feel good now to drive highway speed with the 39,5" x 16,5" Pitbull Rockers
By the way, I did do some really hardcore test on those cylinder mounts and I do know now that something else will brake before the mounts brakes.
The mount on the right side in that one you can lift the hole truck front in the air and it doesn't even bend. I gave the left mount with a hammer and even a sledge hammer, and it barely made any marks. I did not give it with full force with the sledgehammer because of the ball joints and I think the hole tie rod vill bend before the mount brakes. I am going to make some "FAKE" design so it will only look like the left mount would be bolted on even if it is welded.
  #33
Old 10-01-2012 | 05:29 PM
2000silverbullet's Avatar
2000silverbullet
Very cool!
  #34
Old 10-01-2012 | 09:02 PM
Quad Racer's Avatar
Quad Racer
Nice job Linne. Thanks for sharing. The mounts looked pretty beefy to me, but I'm just a carpenter. haha. Looks to me that that mod is heads and shoulders above a typical dampner. I am assuming if it is a power assist that it is also a dampner right?
  #35
Old 10-02-2012 | 04:20 PM
Linne's Avatar
Linne
yes it also works as damper, and I must say I have never done any mod this useful I am so happy with the outcome, I can't think of any reason to buy a complete kit when this can be done so cheap, the fittings are with 1/4" thread and the hydraulic hoses are 1/4" hydraulic hose that is good for 5800PSI but I know that 2000 PSI would be enough.
I only couldn't find anything else than 5800 PSI hose
Hoses and fittings cost me aprox $140
Cylinder was another $100
then a few hours of work and wola you got your self a hydro assist
  #36
Old 10-03-2012 | 08:05 AM
drey04's Avatar
drey04
Nice work! Well done!
  #37
Old 10-03-2012 | 08:54 AM
Benchwrench's Avatar
Benchwrench
Nice,
that power assist should be dubbed
the "ATS steering mod"
(Any Tire Size)
Will it also act as a stabilizer for tire shimmy at speed?
Linne, Did you use TECTYL 2423 in an aerosol or what?
very nice fab job.
  #38
Old 10-03-2012 | 05:20 PM
Linne's Avatar
Linne
Glad you like it
Originally Posted by Benchwrench
Nice,
(Any Tire Size)
very nice fab job.
Lets call it ATS steering mod thank you and nice that you like this mod.
Yes it also works as stabilizer, but if you put too big hoses and bigger than 1-1/2" bore cylinder then it could be that your steering will get so light that it would make it difficult to drive in highway speed.
I can't remember what TECTYL I used but yes in aerosol it is.
  #39
Old 10-09-2012 | 03:54 PM
Linne's Avatar
Linne
I finally got my slef a lift that can lift my truck, I have the lift almost done, still needs a clean up and new paint...
  #40
Old 10-09-2012 | 10:46 PM
Quad Racer's Avatar
Quad Racer
Alright Linne. Pretty sweet lift. Are you preparing for something we should know about? haha. A buddy of mine has a similar lift. I dont think he's ever used it though.
  #41
Old 10-10-2012 | 01:04 AM
AntiBling's Avatar
AntiBling
Nice looking truck, bumper should really finish that off nicely. Any pictures of that roof rack? Pictures of how it's mounted?
  #42
Old 10-10-2012 | 03:37 AM
Linne's Avatar
Linne
Sorry to dissapoint you Quad Racer I was only testing the lift I came over it for almost free so that's why I have been installing it. It's good to have a lift like this, but I'm not really preparing for anything special
Do you use facebook? then you can see the pictures here https://www.facebook.com/media/set/?...1&l=c3f61b8185
I could not find the orginal pics right now so I can't post them here right now...
  #43
Old 10-12-2012 | 03:55 PM
Linne's Avatar
Linne
Today I did put my new "BIGGER" emblem in the grille so it matches better the size of the truck.
I also started welding together all the bumper pieces.
  #44
Old 10-13-2012 | 05:38 PM
Linne's Avatar
Linne
Today I started to fab the inside of the bumper, and I got almost done with the mounts for the winch bed.
I think the welds are getting better and better for every weld
  #45
Old 10-14-2012 | 12:30 AM
BigPigDaddy's Avatar
BigPigDaddy
Looks very nice!
Will your tires clear the ends?
