fuel in coolant?
Old 03-26-2012 | 10:29 PM
fordpride's Avatar
fordpride
Old 03-26-2012 | 10:44 PM
ReBilld's Avatar
ReBilld
What exactly happens to the injector cups, do they crack? What do you look for as far as a bad one?
Old 03-26-2012 | 11:14 PM
oldbird1965's Avatar
oldbird1965
In our motors the 'gold' isn't any good and eats away at the sealant under the cups causing them to leak. Yes, a cracked one will do the same. I think, I'll let the guru's chine in.
Old 03-26-2012 | 11:22 PM
ReBilld's Avatar
ReBilld
Just wondering. I've had injectors out but never messed with the cups.
Old 03-27-2012 | 12:36 AM
oldbird1965
Me too, I don't think you have to mess with them unless they are doing the above. If treated right, they will last a long time. When I did my injectors a million years ago I never even looked down the hole, LOL.
Old 03-27-2012 | 07:56 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
The sleeves could last forever, or they could split apart on any of us tomorrow.
There's really no way to know....
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old 03-27-2012 | 08:19 AM
fordpride's Avatar
fordpride
When you check the cups use a good light and a mirror. You'll be surprised at the scratches and hair line cracks you can see that your eyes can't
Old 03-27-2012 | 12:37 PM
pjwoolw's Avatar
pjwoolw
As stated above. Riff Raff has every thing you will need to swap out those cups. There are detailed instructions in PDF format on the website.
With that many miles on the injectors I'm sure its time for some work there. Along with glow plugs if they have never been addressed.
Old 03-27-2012 | 04:41 PM
muscle66's Avatar
muscle66
Thanks for all of the info. you guys are awesome. This truck use to be part of a fleet, owned by my old boss, so I have invoices on almost all repairs. Is it weird that only 6 of the 8 injectors have been replaced (that i can prove) 2 of which by me when i purchased it? I have no idea how i can afford new injectors... Anybody want a 80% restored 1973 19 ft Mako Center console? Truck is more important then finishing that project...
Old 03-27-2012 | 08:55 PM
fordpride's Avatar
fordpride
Get the cups figured out first. You may not have a injector issue it could be a cracked causing that injector to miss if it's not getting the right amount if fuel
Old 03-28-2012 | 10:23 AM
Awitte58's Avatar
Awitte58
Great link to the injector removal writeup! Been lookin for one.
Good luck with your injector cups!
PM sent.
Old 03-28-2012 | 10:05 PM
MagKarl's Avatar
MagKarl
Get a coolant test pump. Pressurize the cooling system with the injectors out and check each cup for leaks.
Excursion Gary
16
08-22-2020 06:06 PM
Scout
03-16-2017 04:15 PM
finallyo3gt
20
11-22-2015 12:19 AM
corksil
04-29-2015 02:00 AM
kush1972
01-25-2014 07:27 AM
