How to fix front/rear sway bar clunk?
Old 03-25-2012 | 03:03 AM
HawaiianPSD's Avatar
HawaiianPSD
Got this awful clunk when making turns or on uneven ground. Pretty much narrowed it down to the sway bars, I hope lol! Tried replacing all bushings with energy poly ones, no help! Was thinking maybe longer drop links since my 01 has a 6" kit on it? Already running drop links that came with my kit, bar ends not parralel to ground, would this be a problem or could it be somewhere else? Need some help guyz, thanks!!!
Old 03-25-2012 | 07:23 AM
hammer65's Avatar
hammer65
Be sure that the link end bolts are good and tight. My clunk came back after I had replaced my bushings. Tightened the link bolts and OK now. I do not have a lift though.
Old 03-25-2012 | 10:49 AM
cps's Avatar
cps
How are your track arm bushings?
Old 03-25-2012 | 11:57 AM
PaysonPSD's Avatar
PaysonPSD
Have you tried removing the swaybar to see if you still get the clunk?
Old 04-02-2012 | 02:42 AM
HawaiianPSD
Removed the end links, sound still there. Tightened the body mounts also, still no help.
Old 04-02-2012 | 03:17 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
When was the last time you greased the zerks on the front steering components? I had bad clunking, so I took my sway bar off to eliminate it. They were still there. When I lubed the chassis ALL of my clunking went away.
Go figure.. If you do what Ford says to do, the truck works better. Whoda thunk it.
kissfan79
05-06-2018 09:30 PM
truckfella
Modular V10 (6.8l)
10-19-2014 06:44 AM
rat49f6
20
03-13-2011 03:00 AM
PsD007.3
02-16-2009 06:28 PM
BillyBob69
1999 to 2016 Super Duty
18
02-21-2008 07:03 PM
