tire size? 235 to 245
Most of these trucks were farmers and contractors who OVERLOADED their trucks on a daily basis. None of them ever came back with a blown out tire. Just worn down to bald
I have not put mine under a load yet... but my 235/85/16s look so much better! no rubbing at all...
Even with a load it should be just fine, just gotta make sure they are aired up (which i do anyway for the load)
they will work much better once im 4x4 too, rather than 215s...
id blow out a set of 235's if i put 'em on my truck im sure.
scroll down to see what size tires he was running.
https://www.ford-trucks.com/forums/1...this-time.html
Some where aling the lines here, it got messed up. I run 235s now anf have for 15 years. I currently pull a 44' giiseneck trailer, and have never had tire problems.
I was just asking about 245s because 235s are becoming hard to find.
I dont believe .75" of extra tread on the ground is gonna get me stuck or blown tires from heat. All duallies need to male sure the dualls are unflated properly, whether u are running 215 235 or super singles........woudnt be dually in that case
Exactly my point, ANOTHER person with REAL WORLD EXPERIENCE. NOT internet BABBLE
I agree. 235s are a VERY common tire
My utility body had 235/85's on it when I bought it. I assumed that was the right size same as my f250. I just bought 4 brand new tires for the back yesterday. I hope there right I'll have to take a picture tomorrow. There kind of close at the bulge. I was going to air them up a little I don't know what the tire guys put em at. They didn't seem that close with the old tires.
#28
I ran 75 outer 72 inner on the last set. With my daily tool and part load I'm only around 7500 no where close to my 10,500 rating. I'll have to see what they have them at I'm guessing around 60. These tires are no where near as close as the ones pictured earlier I'm taking it those arn't 235/85 or my rims are made for 235/85 and those arn't.
#29
#30
Running all 4 tires at the same pressure, always makes the inner ones wear out faster!
How do I know this? REAL WORLD EXPERIENCE!
The middle of the lanes are always abit higher than the sides. Witch puts more load on the inner tire.
I've always ran my outter rears on my motorhome at 75, and inners at 73. Not much of a difference, but on my last set, all 4 had perfect equal wear.
The original set in the back, that were on the camper when I bought it in 2000, all 4 were at 60psi (max psi in those), I kepted 'em like that since they were more than 50% gone, but when I did replace 'em, the inners ones had very noticeable more wear.
