Slip-Yoke bump is back after TSB repair what next?
mercury 2-4-c marine lubricant recommended uses : steering systems,cable linkages,throttle and shift cables and linkages,remote controls,propeller shafts,swivel pins,DRIVE SHAFT SPLINES,tilt lock mechanisms,tilt tubes,hinge pins and trailer wheel bearings,extremely water resistant,won't break down when mixed with water.Contains teflon for added friction reduction and reduced wear.This stuff is used on HINCKLEY (multi-million dollar) YACHTS.My truck does not thump and the downshifts are now smooth due to no more bind at spline.
2009-2010 Ford F-150 Rear Driveshaft Slip/ Bump
Last edited by fittyford; 02-22-2012 at 10:33 PM. Reason: option motorcraft grease
VERY EASY! You need ford cv boot clamp $8.50 Cv boot clamp pliers $9.00 and Mercury marine grease with teflon (2-4-c) part nbr 92-802863a $10.00 3/8 drive 12mm 12point socket ;assume you have late model F150 2008-2012....
FIX slip yoke thump;cut a 3/4 inch heater hose 2 and 1/4inch long,put it into female slip yoke (sideways) then insert the male end of rear drive shaft into female slip yoke after apply ford xg-8 blue grease.Got this fix from a ford dealer mechanic in Atlanta.So...the hose will be between the female slip yoke and male end rear driveshaft exerting a constant mild pressure between the two preventing a bind that cause THUMP.This is supposed to be a final fix.Good Luck!
Whoo Hooo Thank you Ford! My annoying slip/ bump is finally fixed and my truck feels like it should have when it rolled off the assy line. Seriously was losing sleep att night thinking this was how a Ford truck was supposed to feel.
My dealer replaced my entire drive-shaft and the shifting and slow-speed driving is fantastic. Even the shudder I had around 20 mph is gone. I don't know what the problem was but my OEM drive-shaft was really rusty looking even when my truck had 20 miles on it. The new one looks to be aluminum, not a hint of rust anywhere on the driveshaft. I've got the two-piece one and it looks like they replaced the entire thing plus the carrier bearing.
If any of you are still suffering from the bump that happens 1/2 second after you come to a complete stop. The re-grease/ boot TSB I had done twice did not work at all. The driveshaft replacement has.
slip-bump isn't exclusive to ford. I know a few chebbie owners that have been plagued by this issue as well.
i think chebby was even nickle plating the slip yoke, and they still had problems.
i'm guessing it is not an easy problem to fix, there is a lot of pressure on the splines, and quite a bit of movement.
I just used regular high temp bearing grease, so far it hasn't come back after about two months of driving.
Additional post 4-18-12: I crawled under my truck to look things over and much to my amazement, I have the one piece drive shaft and it's aluminum. My truck is an early build 1/2011. It amazes me as to how different some of the truck are based on build dates and locations.
Why would a 4x2 Scab have a two piece drive shaft and my 4x4 has a single piece?
Looking forward to a real solution. Keep your fingers crossed.
Glad to see that it worked for you sir. Keep us in the loop on her future performance issues, good bad or otherwise.
#29
#30
chillman put the 3/4 heater hose side ways between male and female drive shaft splines and you will never have a problem again,even if there are burs on the splines. I used this solution with xg8 ford blue grease on my truck 5000 miles age and on my nephew 2011 ford 150 ecoboost 3000 miles.This ends your thump PERIOD! If your problem returns,give it a try (marine or xg8 ford blue grease)
