How do they do this eBay aux input cd6 solder?
Old 05-01-2018 | 01:43 AM
akajammer's Avatar
akajammer
I felt compelled to add a few photos to this thread as most certainly should help those with a slightly different configuration CD changer board.
This is a 2002 explorer limited with an Audiophile in dash 6disc changer, w/ rear sub - ford p/n: 3R3T-18C815-KA
I initially found this on youtube:
Pay attention @ 4:35. The photo's above by esm2 also solder in before the surface mounted resistors. (the video states capacitors, I believe in error)
Not sure it matters, but even though I did have some nice meaty solder joints after the resistors, I opted to follow the stated technique.
Now that I have an AUX port....bluetooth to follow.
Hope this helps someone.
Old 12-03-2018 | 01:49 PM
Caden Cruickshank's Avatar
Caden Cruickshank
Aux input hacking CD player line
Originally Posted by dave7219
Once again a few years have gone by before this thread was updated. Well here is the update. The thread is gold. User esm2 posted the perfect instructions and pictures for me to apply to a 2004 F150 Supercrew. Same idea - take out the Head Unit, easily remove the top cover (2 torx screws), remove the CD unit (4 torx screws) and carefully undo the ribbon cable. Turn CD unit up side down, look near the ribbon cable connector for 3 small test points on which an aux cable can be soldered. There were labels on the PCB that clearly identified the left, right and ground. Burned a 'silence' CD and good to go, sounds perfect.
I routed my cable down through the cigarette lighter with just enough slack for iPhone to sit up top.
I am trying to achieve the same thing as you did with your 2005 SCREW. I have a 2006. For some reason the motherboard of my Cd Player is not labeled. Could you upload a picture of your set up or sketch up on my photo? Thanks in advance.
kyleag89
17
08-17-2019 05:49 AM
95YJman
1999 to 2016 Super Duty
07-29-2012 10:19 AM
AndeyHall
03-30-2011 12:24 AM
Brentano
01-09-2006 03:59 PM
lionhart
10-26-2005 10:46 PM
