Batteries
Batteries
What batteries do you guys like to use?
i load tested mine today at school they are RIGHT on the edge of being unreliable in real cold weather.
i know about g-31's but i want plug and play. i don't want to have to do any modifications to anything.
right now the truck has diehard gold's @875cca.
i was looking at the duralast bats from a-zone. they are 850cca.
thanks for any input.
I used to always run Optima redtops...but i've heard that their quality has gone downhill the past couple years...... Never used one in a diesel, but i have had good luck with Interstate batteries. had one in a jeep and never had a problem. always started in the cold(AMC V8's dont like to crank in cold weather), ran a 9000lb winch with no issues along with aftermarket offroad lights. thats all with a stock alternator. I even accidently ran it over with a chevy crewcab dually one time and continued using it with no issues .
I run Les Schwab XHD series in mine. 875cca 750ca Been good batteries so far, had them 3 yrs. Cant remember who makes them for them. Mount right up just fine.
Thinking about going to their step up series they offer a smaller 1000cca 800ca but has less reserve. Since seeing NMB2's success with cold weather starts on a single battery, im thinking of ditching the second for room. After all, if you have to crank it for more than 20 seconds you have something in need of fixing anyway, and any single battery should be capable of that.
i've been using an optima i bought new just less than 3 years ago, and had it tested today because i had a feeling i was cranking too slow. put out 644 CA, rated 1000ca/800cca, so failed the test. battery it was mated with was dead, dropped to 9 volts during the test, and got replaced with a new carquest battery, 1020ca/850cca. holy hell, it cranks twice as fast as it ever has, and without the voltage drop!
for a long time i swore by optimas, but seeing this one fail a test so soon has me concerned with the quality
I use the Oreilly Auto Parts brand Super Start Extreme....ran the **** outta them with multiple headlights, running a light trailer and using all my accessories on the stock alt....I even ran them completely dead(left key on). Put them on a charger....45minutes of charging apiece, back to normal....never had a problem in 4 years....
