could use some help please
hey guys my 06 sd diesel would not start so i boosted it started right up but when took the cables off nothing in the cab would work windows heater fan dash nothing but the tuck was runing fine so put the cables back on everthing was working left it for awhile and shut it off and same thing agian if any answers would help new to the fourm its great hope somone can help
Your alternator has failed. = No 12V
Your batteries are dead from supplying all of their available power. = No 12V
The electrical will work when there is the power from the boost vehicle. = +12V
Removal of the boost source removes the 12V available from it. = No 12V
A diesel will run after start without 12V.
It needs 12V to start though.
BUT everything else on the truck needs 12V to function.
Take your alt to the parts store and have it tested.
Then bring the new one back and install it.
I hope that your batteries are still good (?)
Charge them with a plug in charger NOT the new alternator.
WELCOME TO FTE!
WELCOME TO FTE!
WELCOME TO FTE!
WELCOME TO FTE!
I have to agree you can check and see if your alternator is good on the truck take a volt meter your voltage should 13.1-14.8 if it is in the 12v range your alt is shot
and charge it with a battery charger they actually do a full charge
A diesel engine does not use an electrical spark to ignite the fuel mix.
The fuel is squeezed (COMPRESSED) by the piston which causes the fuel mix to heat to combustion.
They explain it much better than I do at;
HowStuffWorks "Diesel Engines vs. Gasoline Engines"
85_4x4XL
01-12-2011 12:17 PM
5004man
11-10-2007 08:55 PM
