ficm wiring diagram-pinout
I broke the connector on a 05 truck i am working on.the big connector broke. I was wondering what all these wires go to. I have another plug that i am in the process of resplicing all the wires into but i am wondering what all these wires do? If there a pinout and wiring diagram for the ficm somewhere? I know most of the wires hook up to the other computer on the fender and the power wires go to another plug there. But how does the ficm know which injector to fire? Is there 8 different signal wires going to the ficm from the ecm?
Here is the wire diagram for your truck. The FICM connectors and pin numbers are clearly identified.
I also posted a write up on replacing the connectors as well.
Good Luck on the repair.
Awesome writeup! I tried to put all the little connectors back in there but it didnt work.. i cut one off another wiring harness and spliced it all together. Got it running.. but now i cant get the y pipe to line up to the turbo and it has a bad exhaust leak... Its fighting me every step of the way.
If the exhaust leak is at the Y pipe connection at the manifold, I used the crush gasket mentioned in this thread. Worked great! I have also read of people using a ratchet strap to pull the Y pipe in line with the turbo, then tightening the connections. Good luck with the repairs.
FICM Harness wiring question?
When u did this did u mark the (5) black/purple and (4) green wires to the plug or does it really matter to which injector they go to? Im in process of doing the same repair but i didnt want to solder the blacks & greens before i know this?
TIA
Nick
TIA
Nick
If needed you can loosen the driver's side manifold to y-pipe connection and the y-pipe to passenger up-pipe, but I have rarely had to do that myself.
Josh
derfixr
08-21-2004 03:50 PM
