Heated seat change over
New to the site. I've been researching here on a project for some time and am about to get underway. I'll be changing an '03 F250 2wd into a 4wd and upgrading from the old heated power seats that cut off all the time to the continuous heated seats from the '06 F250 4wd donor truck. In regard to the seats, any advice appreciated. Is there a way to just use the current conectors? Do I need a different wiring harness? Will they work if I just run power directly to them and skip running through the regular connectors? I have no idea about any of the above. In regard to the 4wd conversion, I am already aware that I am an idiot, so no need to tell me. Thanks for the help in advance.
Do a search on the site , there was somebody not to long ago that did the same exact thing and gave the info on how to wire them up. Good luck on the project and if you can take lots of pics and do a write up on the 4wd conversion that would be great because that question come's up on here quite often..
Here's the link to the seat thread I was thinking of , hope this helps.
Wiring power seats into my 2008 F350 XLT
KoolAidMan888
1999 to 2016 Super Duty
02-16-2012 09:28 PM
