Service Engine Soon light keeps coming on???
Old 01-08-2012 | 06:33 PM
4x4countryboy's Avatar
4x4countryboy
OK, will do...lol Ya I try to do as much work myself as possible.
I just filled up with diesel (about 10gallons) and used the truck to pull a trailer for work, drove a total of about 60miles or so. Anyways....no S.E.S. light this time.
The ONLY thing I did differently was NOT put in any Diesel Kleen when I filled up. Is it possible that I got a bad "batch" of Diesel Kleen?
ges we'll see what the codes read tomorrow.
Old 01-08-2012 | 10:23 PM
HD Rider's Avatar
HD Rider
The reason I ask you not to let the dealer fix it is because they are known for throwing parts at it untill fixed. Most don't know diesels very well and being an aged platform they are even less knowlegable on the 7.3.
Here is the AE scan tool. Riffraff Diesel Performance Parts: 7.3L Diesel Diagnostics | 7.3L Powerstroke Diagnostics | Diesel Diagnostics - Maint./ Tools/ Diagnostic They are about the same price anywhere so no need to shop around. They allow you to watch live sensor data while you dive or data log information so you can view it later. It is truely and amaxing tool to have. Save your pennies for one and it will pay you back with the money you save.
Old 01-12-2012 | 09:22 PM
HD Rider's Avatar
HD Rider
Did you ever get those codes read?
What did you come up with?
Old 01-12-2012 | 10:37 PM
4x4countryboy
I have tried taking it to the shop for the last 2 days but since he reads codes for free I guess hes not in to big of a hurry to do it...Also my light has quit coming on? Hasnt been on in 3 days and I have drivin about 250miles. Ran Diesel 911 through it today and yesterday....everything seems normal...still think I need to get it checked out? I will just set up an app. with the local FORD shop I guess if ya'll think I need to.
Old 01-13-2012 | 02:00 AM
rwdfan's Avatar
rwdfan
Go to Autozone, they will pull codes for free. Some oil lube shops sometimes will pull them for free, just check around. Otherwise, I'm with everyone else, dont throw parts at it, there are so many problems that could cause a CEL and ABS light, you would likely never replace the right one without knowing the CEL code. If you have to, pay to take it to a shop with an actual scanner, not some little pissant shop with a oreillys or harbor freight scanner, go to one with a good Snap-On scanner or equivalent. Their scanners can read codes that are soft codes or pending codes. I know my truck has a oil temp code, and my scanner will not pick up the code unless I scan it while the CEL is on. That's how most scanners are. Make sure you write down the code and the description and post back here.
Old 01-13-2012 | 11:03 AM
Studawg's Avatar
Studawg
Thread Ender
Never heard of an auto parts store that has the ability to pull codes from the 7.3.
Old 01-13-2012 | 06:12 PM
4x4countryboy
Yes local auto parts stores do not have high tech enough scanners for my diesel...but they work for the gassers. Anyways...any opinions on whether I should wait to see if the light comes on again to get it checked? Its been 4 days since I have seen it and truck seems to run fine?
Old 01-13-2012 | 09:10 PM
gradyc's Avatar
gradyc
wellhead
Originally Posted by 4x4countryboy
Poteau,Ok...near ft smith Ar. thats about the closest "big city".
Whats an AE?
Hey Country, I am in Russellville,Ar. I have the AE. If you are ever down this way. PM me and I will give you my cell no.
We can check the 7.3 out.
Old 01-14-2012 | 04:20 AM
rwdfan's Avatar
rwdfan
Any normal off the shelf OBD2 Scanner can pull codes from an OBD2 equipped diesel, they just cant do the advanced scans, like cylinder contribution tests and injector buzz tests. I know, I have a EDGE cts scanner and it pulls codes from my truck fine, but nothing else. I've also seen my local lube shop do it on a 7.3 a few months ago, the guy just drove it off the lot and came up the street and threw a cel and pulled in. They had just a normal OBD2 scanner, no snap-on or anything and it pulled it right up.
Old 01-14-2012 | 09:46 AM
caverjoe's Avatar
caverjoe
If it is running fine with no light I would put any and all money toward an AE and not have to worry about this problem next time.
I waited to get one and should not have. It is nice and I still dont know everything about it.
While we are talking about this is there a list of normal parameter readings somewhere???
Old 01-14-2012 | 09:50 AM
4x4countryboy
Ya I should,...waiting for some stuff to sell....and trying to get a new job so money is tight at the moment....i know story of everyones life right now lol.
Thank ya'll for all of the input...think I'm saving for a scanner.
Old 01-14-2012 | 10:26 AM
Ponyboychris's Avatar
Ponyboychris
Yes, our trucks have OBDII connector, however they are OBDII exempt. Meaning most OBDII scanners will not work with your truck (including Autozones, O'Reilly's etc). Unless they are designed to read diesels, they won't get you the proper code read and/or show no codes present.
Bathroomdiesel
21
03-31-2019 12:00 PM
chrisginco
04-25-2013 05:36 AM
d_stange
17
08-10-2006 04:04 PM
postonman2004
11-17-2004 11:31 PM
nightshifter
Aerostar
07-31-2004 04:24 PM
