1976 4x4 Crew-Cab HighBoy bed spec's question help...
Great pics and info. I just put a short bed on my 76 crew 4x4 from a 76 f100, but the front holes had to be redrilled as well. And as far as the rear braces, I just had to scoot them in to match the frame width, and didn't have to add the blocks on the very back because it sat flush on the frame.
Hey this truck did it spend some time in oregon? I'm looking for my grandfathers old truck he traded it along with his trailer for a car because the truck broke down during a cross country move. He passed away last year and I've been looking for his truck now for months if there's any chance you can check the owner history for a Leroy bruesch or a Lola bruesch? Maybe I can clear this off my list or maybe I've found blue.
I have a 1979 F-350 Ranger XLT Crew Cab and I have the entire history as it is a local truck. It has 77,000 miles, 2 wheel drive, 33 1/2" frame rails, 460 automatic with tilt. I talked with the last person who drove it and it was parked 20 years ago. It has no shock mounts, Dana 70, 410, Limited slip. No rust anywhere. The truck was complete when I bought it except it was missing the hub caps. I am doing a frame off as I want it to be my daily driver.
1973/77 F250 4WD's (High Boys) available as a Cab & Chassis; Styleside or Flareside Pickup; Crew Cab with or without a pickup bed, w/a factory installed Platform (flatbed) and Platform & Rack (stakebed).
1973/76 F250 4WD, 1977 F250 4WD before serial number Y20,001 (all High Boys) have 33 1/2" rear frame rails (behind the cab).
1973/79 F100, 1975/79 F150, 1973/79 F250 2WD, 1977 F250 4WD from serial number Y20.001 (not High Boys), 1978/79 F250 4WD's have 37 1/2" rear frame rails.
1973/79 F350's on the 140" wheelbase have 33 1/2" frame rails, other 1973/79 F350 wheelbases have 37 1/2" frame rails.
1973/76 Styleside Pickups have exposed fuel caps. The fuel caps are behind doors on 1977/79 Stylesides.
The filler necks used with fuel doors are not the same as used with exposed fuel caps.
smaynor
03-05-2003 05:39 PM
