C6 vent line? Can't find it?
Old 12-28-2011 | 01:18 AM
kcode's Avatar
kcode
I put the small block C6 in my truck and need to hook the vent line up, but can't find the little modular that it hooks up to? Any pictures of where it should go?
Thanks
Old 12-28-2011 | 01:22 AM
fmc400's Avatar
fmc400
MSEE
There isn't a vent line, unless you mean the modulator valve. The modulator valve is on the passenger side behind the pan. It runs to manifold vacuum from the intake. This is a vacuum signal and not a vent.
Old 12-28-2011 | 01:34 AM
kcode's Avatar
kcode
You are correct, my terminology was incorrect. I will look in the morning.
Thanks
Old 12-28-2011 | 10:57 AM
mikeo0o0o0's Avatar
mikeo0o0o0
The modulator is the small "can" at the back of the pan, below the cooler line. It's the one with the rubber hose connecting it.
Old 12-28-2011 | 05:42 PM
kcode's Avatar
kcode
Thanks, that picture helps a lot.
Old 12-28-2011 | 05:47 PM
GreginKy's Avatar
GreginKy
Very fine frame up work Mike !!
Old 12-28-2011 | 05:57 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Thanks, here are some better pictures of how it looks now.
Old 12-28-2011 | 09:52 PM
jgavac's Avatar
jgavac
What is the modulator for? I don't think mine has a vac line going to it
Old 12-28-2011 | 10:11 PM
OldStyle's Avatar
OldStyle
Rusty Roller
Read here: What is the modulator for?
jrockdiddy
06-23-2015 07:43 PM
winginit
05-16-2015 06:03 PM
johninraleigh
12-08-2007 06:19 PM
bigjim22
08-27-2006 09:16 PM
dcdave
02-20-2006 06:46 PM
