dyno day v1
Old 12-17-2011 | 10:59 PM
91dirtydiesel's Avatar
91dirtydiesel
dyno day v1
so as some of you may know there was some built up idis ( nmb2 and racin) here is how things went today
Dyno day 12/17/2011 Erics automotive, Enumclaw, WA
Name/Truck/(WHP/WTQ@Peak Boost)/Mods
NMB2 (out)
Doug/ 2005 5.9 6-spd/(311/589@??? boost)/Thru Muffler.
RacinNdrummin/ 1988 7.3 5-spd/(235/477@18 <acronym title="lbs per sq inch">psi</acronym>)/S362,DPS turbo cal,J2 CAM,IC'd
Typ4/ 1991 F350 5-spd/(218/461@14psi)/60-1 wheel,CAI,typ4 cam, IC'd
91dirtydiesel/ 1991 F350 5-spd/(202/419@17psi)/ATS turbo,Intake tube & filter,5" exhaust
Totalled/ 1973 F350 390 Auto/(203/293@N/A)/4bbl,intake,RV cam,headers
Chris Tongue/ 1985 Chev 6.5 Auto/(138/285@12psi)/Banks Turbo Kit
Papastruck/ 1986 F350 6.9 auto/(123/384@10psi)/Banks Turbo,Baby Moose,Exhaust
Pirate4x4 guy/ 1992 F250 7.3 5-spd/(123/283@N/A) Dead Stock
nmb2:
Originally Posted by NMB2
I have been up for 36 hours now.
I got the truck running with lots of help from totalled and a little bit from typ4 and his buddy Dan.
We were on our way to the dyno and I made it 20 miles when I realized my temp gauge was reading normal but my heater was cool.
Pull over, figured it hit an air pocket, I put a gallon of water in, and it starts pouring out of my bellhousing.
Freezeplug that was installed last night wasn't done right, and fell out.
so needless to say there will be another
pics and vids coming
Old 12-17-2011 | 11:18 PM
starmilt's Avatar
starmilt
Do you happen to have the rpm's they hit their at.
Did they printout a graph or did it just give the peaks.
Old 12-17-2011 | 11:22 PM
91dirtydiesel
yes we have a comparison between type4 and racin...peaks and rpms on cams are obvious the "torque cam" reaches it much sooner and holds it good....pics of print outs coming
Old 12-17-2011 | 11:25 PM
starmilt's Avatar
starmilt
Great that is the ones I wanted to see, thanks.
Old 12-18-2011 | 02:21 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
thats what counts when setting up an engine for work duty right there.
im so exited to see his chart i can't stand it!
looks like you put down some good numbers yourself there 91! congrats man!
Old 12-18-2011 | 02:38 PM
91dirtydiesel
Racin will be posting the pics and vids so when he gets around to it I'll copy them.
And thanks! I was a little scared at those boost #'s. My 1st run I backed off at 2800 rpms because I was getting close to 20psi (18-19) and was at 198 hp... Hooked WG back up and got 17ish psi and 1200 egt at around 3200rpm with 202hp. Torque was the same both runs. And I didn't get a chance to put the timing meter on it so who knows I might have more in her!
Old 12-18-2011 | 03:05 PM
Coalroller's Avatar
Coalroller
sweet dude! thanks!
Old 12-18-2011 | 04:19 PM
typefour's Avatar
typefour
When nmb is dialed in we are going to do a timing day down here in portland cause there a lot of members that want to come from eastern or and such.
I did nothing to mine except the new air filter, I was happy with my 80k daily driver .
And on my alst pull we checked and i ONLY HAVE 2PSI gotta fix that.
Old 12-18-2011 | 07:31 PM
91dirtydiesel
Originally Posted by RacinNdrummin
here are some pics
Old 12-18-2011 | 07:34 PM
91dirtydiesel
Old 12-18-2011 | 07:38 PM
91dirtydiesel
take note that the vids weren't of the big runs as we did several and didnt record every pull
Old 12-18-2011 | 08:42 PM
91dirtydiesel
racins dyno sheet and info
First of all, I know there is a lot of disappointment in what my numbers showed on the dyno, as there was a lot of expectation considering the work I put in on my setup. Let me just point out that other than my studs and cam/springs, I have a 100% stock 160k 7.3IDI longblock. My custom manifolds and hotside only serve the purpose of spooling the turbo as quick as possible, and as Typ4 can attest, gets the turbo (Which technically should be more laggy than stock) going at least as fast as stock if not quicker. My custom split intake was to serve the purpose of removal with studs (And as I look at it now, more of a pain than its worth) The mods to it were to even out cylinder flow and get rid of the stock hat for a positive seal, there was no porting of any sort on my manifolds. The bread and butter of my engines performance is going to be delivered by the Turbo and the IP, unfortunately the IP just weezed out.
I started at 203/445 on my first run, which was really disappointing to see, what was even more disappointing to see was when I started advancing the timing, the numbers actually began to drop, and the more I advanced it, they more so they did. We decided to go the other way and retard the timing, and I was really suprised to see the numbers make big gains, til eventually it didnt make a difference. We then proceded to play with fuel pressure and got some minor gains, and then we kinda hit a wall, this was around the 225/470 mark. When Russ arrived with Dan, and they put their experience to my setup, we ended up playing with the RPM, setting the fuel pressure (with a decent guage) and messing with the torque screw... This equated to 10whp and 7ft/lbs and that was all we could squeeze out of it, it was just done. In total I made about 10-15 runs and this was the result:
The truck now drives exactly how that comparison looks, it feels completely different, and much more fat in the middle. Im very happy with the performance, and while I had 250whp/500wtq as an expectation pre dyno, im still impressed with my engine as it is, and it will do everything Ive set out for it to do.
You guys have to remember, what my truck laid down is in "bolt on" mod 99-03 7.3 PSD territory, and probably does it at a lower RPM.
Now as far as the future goes, My plan is to A) buy NMB2's DB4 (If he will still sell it to me) If not, then B) Get Ken to build me a DB4 and if he doesnt want to do that, then C) I will figure something out whether I have to build my own pump, or find a better option than the DB framed pumps. Also, Im going to build myself an intake the same as I built for NMB2, as I think its plenum and flow area is better, not to mention its a cleaner setup and I can eliminate the plenum box I made.
Other than that, I see no reason to change my setup. Im going to leave my CR stock, as there wasnt even a hint of diesel ping, and with my turbo and IC, I think it would do mid 20's boost and not have any problems.
Anyway, thats all I got for now, if I remember anything else I forgot, Ill make sure I post it up.
Old 12-18-2011 | 08:52 PM
starmilt's Avatar
starmilt
Those numbers are actually pretty nice, If I am reading it right your peak torque was around 2500 rpm's.
Old 12-18-2011 | 08:58 PM
91dirtydiesel
here ya go
So I think one of the biggest benefits of the dyno run yesterday was that we got to see a comparison between the two IDI "upgrade" cams, The tried and true Typ4 "Torque" cam and the new J2 "powershaft" that NMB2 and I have in our trucks.
After I made my runs, and Russ made his runs, we overlaid the graphs and this is what we got:
Now, instantly when I saw the graph, I thought, holy crap, the Torque Cam handed the J2 cam its ***, and in a lot of ways its did. It has a serious ramp and a flat top, flatting out at around 1800 and tapering off at just over 2200. The J2 cam flattens out at around 2200 and starts dropping around 2500... This is all on the Torque side of things, which most consider to be the bread and butter of a diesel engine.
As far as hp is concerned, the Torque cam and J2 cam rise similarly with a slight (but probably un-noticable) advantage to the J2 cam, until the torque cam falls off at a little over 2800, and the J2 cam keeps pulling until redline (and maybe even past, my gov kicked in shutting stuff down).
Now a quick glance at the chart would make most not even want to consider the J2 cam. However, in discussion with Russ, and even more now that I have driven my truck on the freeway since and looked at what the RPM's are doing, We both believe that the J2 cam benefits those with 4:10's better and the Torque cam benefits those with 3.XX:1 gears better. My truck cruises 60mph at 2200 with 4:10's and stock tires and Im right smack dab at my torque peak on the freeway...
Basically, if you like to drive fast or even with traffic for that matter, and you have 4:10's or higher (or equivlent in tire sizes... essentially 2200 or above on the freeway) The J2 cam is probably gonna be a better choice, but if your spend most of your time in the Sub 2k range, the typ4 cam is going to be better suited to you.
Russ, do you have anything to add/change??
Old 12-18-2011 | 09:26 PM
starmilt's Avatar
starmilt
Too bad there was not a turboed rig there with a stock cam to compare too.
In the real world a guy would not realize much difference between yours and typefours with available stock gears.
I will eventually install my zf5 and with the gv would have double over available, so the typefour cam would maybe edge it out a little, but in reality either would work pretty well.
