1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Superduty sound deading
Old 01-10-2012 | 10:27 AM
cartmanea's Avatar
cartmanea
I haven't taken the window out, so I can't say. If you have all the seats out, you could try just dropping it away to the other side to do half the roof at a time. Ou, try rotating it slightly and out the passenger side front door.
  #47
Old 01-10-2012 | 11:22 AM
Lex2002's Avatar
Lex2002
Originally Posted by cartmanea
I spent about $700 deadening my cab, and what I'll say is SAVE YOUR MONEY.
I did the entire floorpan, firewall, kick panels, and rear wall first with RAAMmat BTX and Ensolite products, two layers in the large flat areas that resonate a lot. After spending a weekend doing this, I honestly did not notice much (if any) difference. Later I did the door panels, and that made a significant difference.
I would save your time and money and do just the door panels first, I'm sure you'll be happy with the improvement and it will save all the work of gutting the entire cab.
Here are some pics of my project. Worst part, last year I laid the truck over and am currently rebuilding it with a different cab... Needless to say, the new cab won't be getting this much sound deadening.
WOW! I was about ready to do the same job. Thanks for the input!!!! I will stick to the doors and the steering column fire-wall perforation / passthrough.
Was fitment of panels etc an issue for you AFTER you got the deadening in-place? Ive done a few cars with just Dynamat Extreme and even just that thin layer can obviously cause fitment issues if you place it where parts snap to the body.
  #48
Old 01-10-2012 | 11:35 AM
cartmanea's Avatar
cartmanea
Yeah, door panels were tight, but that was about it. Just be sure to cut larger areas around the clip areas and anyplace the panel has a stand-off.
  #49
Old 01-10-2012 | 05:10 PM
skibell's Avatar
skibell
Thanks for all you input, this really has shine some light into this subject. Hope all is well with you.
Jean Cloutier
General Diesel Discussion
12-25-2018 05:25 PM
octaneforce
05-29-2010 01:49 AM
5.4XLT
Modular V8 (4.6L, 5.4L)
10-20-2007 08:13 AM
Beerstalker
17
02-26-2007 03:00 PM
tabassak
Escape & Escape Hybrid
11-26-2002 08:53 PM
