1978 - 1996 Big Bronco
78/79 Pictures wanted
Old 01-17-2012 | 10:23 PM
Raleigh1's Avatar
Raleigh1
Originally Posted by slayerman54
I have looked at my panels in the past and it was of no help to me in regards to my question. See the new Q-panel has holes for the spot welds but at the part where it butts up to the A-pillar(the horizontal part) it has no holes, therein lies my question. The piece of the Q-panel that is vertical yet curved has holes for spot welds and I see how that gets welded. With the cab off of course, it is easy to run a line of spot welds horizontally along the top and curved piece of Q-panel that connects to the A-pillar. However, you say the right-angle piece that horizontally touches the A-pillar is not seam sealed(yet I see sealer) instead it is welded on. Well, looking straight at the rear Q-panel, the horizontal right-angle piece is folded in towards the body which means the only access to weld it is from behind the Q-panel. How is that suppose to happen?
Everyone that I know of that has replaced the 1/4 panels used seam sealer in that joint.
Most are not welded from the factory for a good reason, to prevent cracking when flexing.
It is a small section and it is very rigid, don't worry about filling that gap with seam sealer.
Or you could just weld it flush and get rid of the gap all together, but if you flex the truck much it may crack.
The 78
Project B-350, rust free 79 Bronco body
And a rolled 99 F350 7.3L Powerstroke, ZF5
  #32
Old 01-17-2012 | 10:35 PM
corytaylor's Avatar
corytaylor
hey
i just uploaded pics of my 79 today....go check them out!
  #33
Old 01-17-2012 | 11:06 PM
GruesomeJeans's Avatar
GruesomeJeans
rahleigh1 those are some good pictures. BTW how do the chains work? I just noticed those as being steps and it seems like a really cool idea.
  #34
Old 01-17-2012 | 11:46 PM
Raleigh1's Avatar
Raleigh1
They are just bolted the rocker, simple. I have enough clearance I haven't needed sliders yet so this works for me!
  #35
Old 01-18-2012 | 12:20 AM
GruesomeJeans
Eh sorry i ment how well do they work. As in, does it make it any easier to get in or do they swing in when you step into them. I have the solid metal ones and they are ok but these intrigued me
  #36
Old 01-18-2012 | 12:23 AM
Raleigh1's Avatar
Raleigh1
Oh yeah, they work great and don't get in the way on the trail.
I put them on for my wife but I use it too, the bottom of the door is 30" from the ground.
  #37
Old 01-18-2012 | 12:36 AM
GruesomeJeans
Hmm i might look into it, they have kind of a cool look about them
skibber
WTB - Parts & other
02-19-2018 07:51 PM
skibber
WTB - Ford Trucks & other vehicles
12-22-2016 09:58 AM
77&79F250
19
07-08-2015 11:52 PM
grey77
Louisiana Chapter
03-31-2005 10:43 PM
hoxiii
05-25-2004 04:31 PM
