FE overdrive
#46
I would go with a Ranger Overdrive if you like the feel of an old truck transmission.
http://www.advanceadapters.com/produ...etainer-index/
I'd look for an adapter for a ZF6 to FE instead of the ZF5. Just my opinion if you're going to be getting an adapter. Other than a new transmission like the Tremec TR4050 that came out this year, you're stuck with a gear vendors unit for overdrive.
#47
Here is a ZF adapter for an FE. You need to spec out a 2002-2010 SD modular gas ZF-6 tranny:
https://transmissionadapters.com/col...ransmissions-1
A diesel trans has a different bell pattern.
It seems the TR-4050 is a 5 speed only for 4wd use with no application for an FE yet:
https://shiftsst.com/4wd
Ford67ranger
04-15-2003 12:20 PM
Ford67ranger
04-15-2003 06:39 AM
bjensen
03-14-2002 12:44 AM
Charles-65F350
02-13-2001 05:19 PM
300, 390, 70s, aftermarket, automatic, block, c6, engine, factory, fe, ford, overdrive, rebuilding, t85, transmission, transmissions
