What type coolant I can use in this 7.3L?
Old 12-15-2011 | 09:25 PM
Stewart_H's Avatar
Stewart_H
Originally Posted by Milwaukee1979F150
It come from Big semi mechanic shop. They get bulks of those. I will check. If it 50/50 it ok to use?
Dan
Not for a refill after you flush the block, no. You need concentrate.
Read my thread here:
Gooch's Coolant Flush Procedure and In-Depth Coolant Information - FTE
Stewart
Old 12-15-2011 | 09:41 PM
Milwaukee1979F150's Avatar
Milwaukee1979F150
Stewart
I was planning pull radiator out and oil cooler. hook to house water to flush all unknown stuff inside cooling system that preview owner put.
I read that I need get dist water from walmart. I think 10 gallons enough since I was going park truck on steep driveway so all fluid inside would had been out easier.
Old 12-15-2011 | 10:13 PM
Stewart_H's Avatar
Stewart_H
There's no need to pull the radiator.
Just read the instructions in the link I provided (it has very good pictures) and follow Gooch's procedure and you'll be fine.
Stewart
Old 12-16-2011 | 12:24 AM
Milwaukee1979F150
Stewart
Radiator had half surface clogged by junk. It look white fuzzily is cover it. I had other 1999 F250 with 253K miles. It was so bad that I end spend 40 mins rise with water. Those water go though radiator it was GREY nasty .
I don't know what that white stuff. I think goldenrod seeds or that picture if anyone know.
Old 10-21-2017 | 06:43 AM
SmokeSIG's Avatar
SmokeSIG
I HAVE A 1999 F 350 7.3 The plate Mfg. DATE is 02/98 I plan on flushing system but want to verify with you more experienced folks as to WHAT TYPE OF COOLANT GOES INTO this MODEL? If I understood the THREADS, my MOD. NEEDS A SCA?? Thanks for any insight. Mike D
Old 10-21-2017 | 09:03 AM
Pitcrw6's Avatar
Pitcrw6
I believe you need to use the green coolant.
Old 10-21-2017 | 09:14 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
There is a thread on here somewhere stating which engines (by serial number) can use the ELC coolant. Based on the build date of your truck, I would say that Pitcrw6 is right and you need the green SCA coolant and cannot use ELC.
Old 10-21-2017 | 09:33 AM
Bill Kay's Avatar
Bill Kay
Your answer is in post #2 of this thread. You are right on the line so I would check the engine serial # to see which side of that line you fall. I had an E99 for years and ran the pink stuff from Tractor Supply called Fleet Charge. It was not ELC and came pre-charged with SCA's.
Good Luck!
Old 10-21-2017 | 09:50 AM
Walleye Hunter's Avatar
Walleye Hunter
Good Luck!
Either he mistyped or you misread, he reports a build date of 2/98, not 2/99. You are right, though, if he has mistyped and his build date is 2/99.
Old 10-21-2017 | 10:08 AM
Bill Kay's Avatar
Bill Kay
That would be...I mis-read! Definitely need to use the SCA charged coolant and not the ELC.
Thanks Walleye for catching that.
Old 10-21-2017 | 02:44 PM
Colorado350's Avatar
Colorado350
Originally Posted by Tim J
Bummer....so I'm destroying my e99 by running Rotella ELC? what would some e99 owners recommend?
I run NAPA green, easy to get practically everywhere.
Old 10-21-2017 | 02:57 PM
Walleye Hunter
Tim J hasn't been active for over a year. I like only having one type of antifreeze in my cupboard as well, works in my car, truck and tractor (they're all old anyway).
  #28
Old 09-28-2018 | 01:36 PM
Josh Ross's Avatar
Josh Ross
Diverdude
I've read many threads as I am getting ready to do a coolant flush, change the original water pump since it has clocked well over 200K miles, change the thermostat and housing, and add a coolant filter, and add a new gas bottle cap. The only thing I would like to make sure is that I am purchasing the correct coolant. My valve cover has December 16th, 1998 stamped on it (for my signature rig). So I guess I have an early '99 model? I also suppose I need the conventional coolant and add a SCA. Have I read correctly? What is the recommended flush interval with all these considerations? Any other good to-do items I left off? Thanks!!
  #29
Old 09-28-2018 | 02:19 PM
hydro man 17's Avatar
hydro man 17
"Have I read correctly?"
Yes, it looks like it per your info. Not sure on the flush interval. I believe that it depends on how well it tests with the test strips.
qman
09-28-2005 05:29 PM
Saxon
08-07-2004 12:15 AM
fhartell
01-01-2004 07:44 AM
Starratt04
06-09-2003 12:49 AM
Starratt04
03-20-2003 04:31 AM
