Fuel in coolant with a Knocking noise
Old 11-30-2011 | 09:08 PM
CSchob's Avatar
CSchob
I have searched many similar threads on here but none of them talk about a knocking sound along with fuel in the coolant. I am under the impression one of two things is causing the fuel/coolant mixture. Either a cracked injector cup or a cracked head. I have read about a few ways to check which cup it is.
The symptoms,
the knock sounds like a mini jackhammer thats really loud when motor is cold. As the motor gets to running temp it quiets down but doesnt go away. At high-way speeds/rpm or under heavy acceleration the knock is almost non-existant. Sooo my question is does a cracked injector cup also cause a knock?....possibly because of loss of compression in the cyclinder? Or would the knock be from something else? Remeber the knock gets quieter when motor gets warmed up and almost non-existant when at high rpms but returns when engine at idle or low speed. Your help is appreciated
Old 11-30-2011 | 09:30 PM
woodnthings's Avatar
woodnthings
They knock really bad when you have an injector tip broken too.
Blowing Grey smoke - YouTube
Old 11-30-2011 | 10:51 PM
snakedoc's Avatar
snakedoc
what may be happening is coolant is getting it the cylinder need to get it looked at it can bend a pushrod or worse
Old 11-30-2011 | 11:51 PM
CSIPSD's Avatar
CSIPSD
Fuel in the coolant is cup issue...99.995%...
Old 12-01-2011 | 01:18 AM
CSchob's Avatar
CSchob
The truck doesnt smoke at all so I dont think an injector tip is broken. It has a banks chip and still doesnt smoke.
I sure hope the knock is an injector related issue though. Anything else will be big bucks to fix. Ugh
Old 12-01-2011 | 01:57 AM
CAPTAIN DIESEL's Avatar
CAPTAIN DIESEL
Find the bad cylinder, remove injector, pressurize cooling system with hand pump, spray small amount soapy water into injector cup and look with flashlight for bubbles.
Old 12-01-2011 | 02:08 AM
Bonanza35's Avatar
Bonanza35
Please keep us posted on the repair.
Chet
Old 12-01-2011 | 07:51 AM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
I had fuel in my coolant and it was a cup. I didn't have the knock though, but I switched all my cups at the same time.
Once you get the valve covers off and buy the cups ,orings and rent the tool from Riff Raff you might as well change them all. Only one of my cups had an obvious crack but 6 of them had some discoloration which may have indicated the orings were going bad.
Old 12-01-2011 | 09:49 AM
Kwikkordead's Avatar
Kwikkordead
I agree, do all eight and be done with it.
Old 12-01-2011 | 10:25 AM
snakedoc's Avatar
snakedoc
there is an injector cup tool for sale he is asking 200 obo
7.3 injector cup tools!!! - PowerStrokeNation : Ford Powerstroke Diesel Forum
Old 12-01-2011 | 02:26 PM
Bonanza35's Avatar
Bonanza35
Yes do them all. Same with glow plugs etc..
Chet
Old 12-02-2011 | 01:03 PM
CSchob's Avatar
CSchob
Thanks for the advise. I took it took a couple different shops and they gave me a conservative estimate of about $1,000 to find the cylinder that has the leak and then replace the cup. Maybe it would be cheaper to just replace them all instead of spending the labor hours to test each cylinder. They also said the leak is probably causing the knock because I'm either losing compression or have excess fuel in the cylinder. I will probably take the truck to get fixed in the next week.
Why would i need to replace the glow plugs?
Old 12-02-2011 | 01:54 PM
Bonanza35's Avatar
Bonanza35
Your in there and they are cheap. Just make sure they don't charge you and arm and a leg to do a five minute per side job.
Chet
Excursion Gary
16
08-22-2020 06:06 PM
finallyo3gt
20
11-22-2015 12:19 AM
zeppelingto
12-13-2012 12:33 PM
Brian0445
07-06-2012 06:30 AM
avidbow
07-24-2006 07:27 AM
