location of ignition coil ballast resistor
thanks for the help. I'm still wondering if i even have the resistor wire on my rig, i check the voltage at the coil positive lead and it showed 12 volts. My truck also idles rough but all the plugs seem to be firing, so i have a theory that the high primary voltage arcs across the points when they open preventing the coil from firing. anyone have this problem before?
Well if you are sure you do not have it....you can go to the parts store and get a 1.05-1.15 ohm ballast resistor. Then put it in series with the coil +. That will drop the voltage down to close to the factory settings.
Of course then you will need to run a new wire from the "I" terminal of the starter to the coil +. That way you would retain the 12 volts during startup, and the resistor should give you the correct lower voltage during running. I think it is 9 volts or so.
Be sure to check the coil + voltage with the points closed or with a jumper wire from the coil - to ground. If the points are open you will measure +12 volts with or without a ballast or resistor wire. No current flow means no voltage drop.
If the points are arcing a lot, you probably don't have a ballast or the condenser is shot.
Barry
Barry
You need at least a coil to test it. The resistor wire and the coil primary windings are connected in series and form a voltage divider. Approximately half the supply voltage is dropped across the resistor wire and the remaining voltage is dropped across the coil primary. Use a stock coil for the test, a high-performance coil has a lower primary resistance and will throw off the voltage divider. That's why they have matching ballast resistors which are lower in resistance, to restore the divider.
Barry
Barry
I should think that, with the ign sw "on", there should be reduced voltage at the "Bat" coil wire, even if the coil isn't there? I have converted 3 Allis-Chalmers tractors fom 6V Neg Grd to 12V Pos Grd using Ford alternators, coils and regulators. I have used the "pink" resister wire and in one case (these tractors don't have a starter on the switch), I am feeding reduced voltage to the coil at ALL times and it starts just as well as the others that get 12V at "start".
Yeah, you would think that but with no load there really is no voltage drop, it has to follow ohms law. A cheap voltmeter typically has 20,000 ohms per volt compared to the 1.5 ohm resistor wire so it's practically not there as far as the resistor wire is concerned.
You're right, the coil doesn't really need 12 volts on start but it sure would like it on those cold mornings.
Barry
Barry
I found the resistance wire on my '68 -- it is kind of a dark orange color with "DO NOT CUT OR SPLICE" printed on it. The start by-pass lead joins it at the connector to the engine harness (coil, water temp, and oil press). I tested it with my ohmmeter and it read 6.7. I then tested my chrysler electronic ballast resistor (a Standard RU-4) and it measured 1.4. As I am changing over to an electronic igntion (which should be 1.1 -- 1.8 ohms) I am going to by-pass the resistance wire and put the chrysler unit in.
Chris Seay
Bealeton, VA
'49 F-1s
'68 F-100
Chris Seay
Bealeton, VA
'49 F-1s
'68 F-100
I remeasured the resistance wire in my '68 -- the first time I checked it I checked it THROUGH the ignition switch and came up with 6.7 ohms . . . I disconnected the ignition switch and measured JUST the wire and came up with 1.4 ohms -- the EXACT same as the chrysler unit!!! I can't believe my ignition switch has that much resistance . . . maybe time for a new one!
Chris Seay
Bealeton VA
49 F1s
68 F100
Chris Seay
Bealeton VA
49 F1s
68 F100
