just ordered a fuel pump
so since getting this '02 i've had an issue with the gauge never reading correctly. it would drop the first half wayyyy to fast then the bottom half took forever. this was totally different then my 2004 or 2000 excursions which were very accurate.
so i've had it stick on full or go to full before. once i filled it up it would start working again. well 2 days ago it did this and i filled up and nothing still stuck on full.
so tonight i ordered a new fuel pump with sending unit. the pump is fine but if your dropping the tank any not do the pump also right?
i'll let you guys know if this fixes the whole issue.
I would definitely vote for a new fuel pump while you are in there. Fuel pumps are the weakest link in the whole chain and they go and hide it in the fuel tank, never understood that. Why not outside next to the fuel filter? (like a diesel?)
Sounds like a typical GM thing. Maybe it's the same sending unit supplier.
Random Engineer "Maybe we oughta put the fuel pump outside the tank."
ominous music........
Rex Kramer (Airplane) "No...... that's just what they'll be expecting us to do."
Airplane - That's just what They'll be expecting Us to do - YouTube
lol i should have mentioned its all new studs for the manifold. turns out 4 of them were busted actually and had to be delt with in a time consuming way. the truck is not done yet i'll get it back tomorrow. they sent the manifold out to be checked for trueness (if thats a word..i think i just made it up)
the pump went in perfectly he said, turns out this is the 3rd pump my truck has had in it! they found another o-ring for the pump assembly in the bottom of the tank. the pump that was in it was what looked like some cheap off brand as it had no motorcraft markings or any others for the matter. i'm glad i replaced it with a brand new true motorcraft part!
arse_sidewards
09-28-2016 07:29 PM
Steve in NC
11-10-2014 06:24 AM
