F350 2004 front end question
I had a rattle in the front end, found to be worn sway bar bushings. I purchased the kit from LMC and pulled the sway bar out, only to find that the ends are different than the new bushings. The stock parts appear to be a combination of rubber, grease, and (rusted) metal and the new are simply two pieces of polyurethane, a brass bushing and large washers.
My question is how do I get all the old stuff out so I can slip the new bushings in?
That_Just_Happened
33
09-03-2010 09:37 PM
