Electric wiper motor replacement question
Joe, check the grease inside the two gearboxes. On the one of mine I opened, all the grease had turned stiff and was around, but not touching, the gears. In other words there was a lot of grease but it wasn't doing any good.
As far as not stopping, there is a little button in the motor switch (on the motor) that rides a cam. That is the parking switch. Mine was really worn and didn't really break the circuit.
The way it was wired, the middle wire is hot (6 vdc) all the time. Is that correct? I don't trust anything the PO did after seeing that "power" lead connected to ground.
I don't have it in front of me, but my recollection is that the cam that actuates the parking switch depends on a plastic pin that pushes on a contact. The contact interupts power going to the unit (so it kills power when the arms get into the right position). If that's out of adjustment or the pin is bad, it could prevent any operation, or make it always On.
I think the choke and throttle have to be some other trick. If they came off with a pull, they'd come of when the cable is all the way out. I've tried twisting them, to no avail. The replacement cables are threaded for new *****, which also are threaded. I didn't see any holes in the *****, but I'll look again. I think they may be glued on.
Wipers work great!
Well, except I'll need new blades whenever I finally drive the truck... in the rain.
I checked the function of the parking switch, and noticed the cam wasn't hitting it evenly, so I made a little molecular realignment with some needlenose, and now it stops and starts like it should.
I put the wiper assembly back in the truck, wired it up, turned it on, and voila! It works. I put the wipers on it to set the stopping position... and I had the gearboxes 180 out of sync, so the wipers were moving toward and away from each other, instead of back and forth together.
Out it came again. Reset the gearing so they're in sync. Reinstalled it, and everything works fine.
The double pole/single throw parking switch opens the circuits between the center "power" connection and the two "speed" connections on either side which are connected to the motor windings. These are shorted to the center power wire while the parking switch is closed.
Yeah, I know... clear as mud. But the wipers work.
I want to put new choke and throttle cables on it. I have the new ones, but can't get the old ***** off the old cables.
I'll probably replace the tie rod next. I got the old one fairly straight, and adjusted the toe, but I really should replace the tie rod. It's on my list.
And I want to tune it and check the timing. It runs great, but hesitates slightly when I step on the gas. I haven't even really looked at the points yet. Since I won't be driving it til I can afford to replace the widow makers and tires, it's really not a big deal yet. I haven't looked at the brakes yet either. Same reason as above.
Then I'm gonna rewire the whole truck. Then I want to put a bed on it. Then eventually, some body work and paint, but I want to drive it for a while first.
#30
Wiper test
We had our first rain for quite a while in Riverside today, so I wanted to test the wipers.
My Ford F4 :: Wipers work video by JollyRogerJoe - Photobucket
I'm going to run a ground wire from the motor body so I don't get "intermittent" wipers.
