cant hook the wastegate actuator back onto the post.. help
Old 10-03-2011 | 01:23 AM
1982_f150's Avatar
1982_f150
when the rod is connected and the truck is off and sitting, what direction is that tang usually?
Old 10-03-2011 | 01:24 AM
PaysonPSD's Avatar
PaysonPSD
Originally Posted by 1982_f150
The tang is currently pointing towards the passenger side
That is the fully open position. No wonder you can't get the rod back over the pin. Turn it back toward the actuator.
Old 10-03-2011 | 01:26 AM
1982_f150's Avatar
1982_f150
is it really tough or should it turn easy? cause i cant do it by hand.
PaysonPSD's Avatar
PaysonPSD
Look at the pic in post 13. Maybe you should start over again at post 6. I think you have missed a few.
Old 10-03-2011 | 01:29 AM
PaysonPSD's Avatar
PaysonPSD
Make sure you turn it the right direction. It will not turn 360°.
Old 10-03-2011 | 01:32 AM
1982_f150's Avatar
1982_f150
i dont understand, i didnt shorten the rod, the tang is pointing toward the pass side and i cant turn it with out forcing it
Old 10-03-2011 | 01:41 AM
1982_f150's Avatar
1982_f150
Old 10-03-2011 | 01:45 AM
PaysonPSD's Avatar
PaysonPSD
It only has about 90° of travel.
At this point you may have to remove the exhaust outlet housing to figure out why it is hung up.
Old 10-03-2011 | 01:46 AM
timmyboy76's Avatar
timmyboy76
pull that tab toward the front of the truck. I got a turbo apart in the garage and went and looked at it
Old 10-03-2011 | 01:49 AM
1982_f150's Avatar
1982_f150
i cant move it! it doesnt turn.. it turned 2 hours ago when i took it off.. arent the controlled by oil pressure?
Old 10-03-2011 | 01:54 AM
timmyboy76's Avatar
timmyboy76
not that one. All the tab is, is a flapper inside the exhaust housing. No spring, oil..etc anywhere there. Only thing that can bind it up is built up carbon/soot...
Old 10-03-2011 | 01:58 AM
1982_f150's Avatar
1982_f150
ok well i put a pair of vise grips on it and wiggled it back and fourth and it came free but then it got stuck again then it came free and i got the rod on.. im afraid to fire it up lol
  #28
Old 10-03-2011 | 02:06 AM
timmyboy76's Avatar
timmyboy76
lol...that flapper/tab, only moves 90*. Starts in the, pointing toward front of truck, and when opened, toward pass/side.
  #29
Old 10-03-2011 | 02:11 AM
PaysonPSD's Avatar
PaysonPSD
Glad you got it free and hooked back up.
Apply some air pressure to the actuator to check operation.
Pic of typical wastegate.
  #30
Old 10-03-2011 | 02:50 AM
1982_f150's Avatar
1982_f150
just took her for a test drive, everything seems to be working fine. the FRx made it idle quieter hmmm.. well see what the new comp wheel is like when im towing later this week.. thanks abunch for all you help guys i really appreciate it
THEDON117
06-06-2015 08:38 PM
Pikachu
21
04-11-2014 01:56 PM
Justin03PSD
05-19-2010 03:57 PM
spdmpo
18
06-05-2009 02:33 PM
HighOctane
04-06-2008 03:41 AM
