My 73 F 250 4X4 semi build thread...
Old 10-07-2011 | 07:43 PM
BlueOvalDismantlers's Avatar
BlueOvalDismantlers
Some guy 3 blocks from my shop actually had them stacked in his backyard under a tarp. He got.them for his superduty but guess what! Wrong bolt pattern LOL. His wife was riding him to move them before winter so he said if I can haul them I can have them, so I took them and bolted them up. I also rust reformed my hubs as they had surface rust. All the lugs were good which was a nice suprise.
AK FORD GUY your avatar caught my eye. I work at the local fire department and am finishing up field for paramedic school (part of the reason I have less truck time than I want) I just ran about 100 feet of 3/4 inch gas line at our training tower for roll over and flash over. 3/4 inch @ 40 psi makes for a good time. It sounds like a jet engine and shakes the conex pretty violently put a huge grin on my face!
  #32
Old 10-07-2011 | 08:02 PM
AK FORD GUY's Avatar
AK FORD GUY
That is one heck of a deal.
My avatar is a pic of our well-house prop, she burns propane and diesel and is a blast to fight . I work a 2 weeks on and 2 weeks off schedule at work. I am on a volunteer department pretty far north, basically the tip top of Alaska. I have been certified for my FireFighter I and am testing out for my Engineering creds next week, FireFighter II will be next on the list. Granted, it's only a volunteer department, but we have a blast training. Up here at work, we do not see many real fire calls.
Stay safe brother
  #33
Old 10-07-2011 | 08:40 PM
73f250highboy's Avatar
73f250highboy
Originally Posted by AK FORD GUY
OK, lets see some pics of them on the truck. *EDIT* You were adding them as I was typing.
Looks great other than the backwards lug nuts. I can't even count how many times I've see that before (I spent 10 years in a tire shop).
How the heck did you score'em for free?
Those ate the 37's I've been looking for up here and no one has any. I did find one set that was pretty worn and weather checked and the guy would not budge from $400.00, too rich for my blood for mostly worn out tires.
You can get some shipped to you itll probably be about 700 for 5 with 90% tread... 100dollartireman.com (no its not me)
  #34
Old 10-07-2011 | 08:50 PM
AK FORD GUY
I actually tried him. I have emailed him twice, no reply either time. I just figured he did not want my business. I'll find some eventually, I am very patient....... are they here yet.....how about now......
socal73 - Have a safe time in Vegas, you know what they say about Vegas...
  #35
Old 10-07-2011 | 08:53 PM
73f250highboy
Really? try calling him
  #36
Old 10-07-2011 | 10:57 PM
BlueOvalDismantlers
Should be good times. I got a smoking deal on a 1600 sq foot suite! It's bigger than my house!
  #37
Old 10-08-2011 | 08:43 AM
Blackfoot Big Block's Avatar
Blackfoot Big Block
Originally Posted by impalaslayer
awesome. you say it had AC but i dont see the big box thing thats usually on the fire wall?
I believe it had dealer installed A/C. If you look closely at the photo you'll see two lines running along the top of the firewall.
  #38
Old 10-08-2011 | 08:17 PM
BlueOvalDismantlers
Anniversary present from my wife!
Woohoo!
  #39
Old 10-08-2011 | 09:50 PM
teds74ford's Avatar
teds74ford
that's quite the cash outlay! She must really love you
  #40
Old 10-08-2011 | 10:12 PM
BlueOvalDismantlers
Haha ya she does. And she likes to go shooting as much as I do.
What a gal!
  #41
Old 10-11-2011 | 12:30 PM
BlueOvalDismantlers
Has anyone changed out their brake booster. I'm gonna tackle that today and any suggestions would be helpful!
Mason
  #42
Old 10-11-2011 | 12:52 PM
montana_highboy's Avatar
montana_highboy
It's a pretty straight forward and easy install, just be sure to check and make sure the booster push rod adjustment is correctly set.
  #43
Old 10-11-2011 | 01:35 PM
BlueOvalDismantlers
I have a haynes manual any extra info or should that cover it?
  #44
Old 10-11-2011 | 02:46 PM
teds74ford's Avatar
teds74ford
Consider upgrading to the dual diaphragm setup. It bolts in, but depending on the master cylinder, you might have a small issue. On mine, the single diaphragm master cylinder has slightly smaller stud hole spacing than the dual diaphragm one. I just took a file and slightly ovaled the holes until it bolted to the booster.
If you go with a direct replacement, there is no magic at all. The only line is the vacuum line, and then there's a couple bolts that hold it on. Easy swap.
  #45
Old 10-11-2011 | 03:41 PM
BlueOvalDismantlers
What's the advantage to switching to dual diaphragm?
Quick Reply: My 73 F 250 4X4 semi build thread...
