94 F150 fuel tank question
Old 09-18-2011 | 01:21 PM
kelly351's Avatar
kelly351
i just bought a 94 f150 and the gas gauge doesnt work. i am trying to figure out how many gallon the front tank is.
Old 09-18-2011 | 01:36 PM
Gramps86's Avatar
Gramps86
ok so its a 94 f150, is it a reg cab, ext cab? long or short box?
Old 09-18-2011 | 01:38 PM
Gramps86's Avatar
Gramps86
also what tank? usually these trucks have 2, a frame side mounted tank (front of rear axle) and a tank mounted between the rear frame rails, behind the rear axle.
Old 09-18-2011 | 01:57 PM
kelly351's Avatar
kelly351
Regular cab long box. It's also 4 wheel drive if that makes a difference
Old 09-18-2011 | 01:59 PM
kelly351's Avatar
kelly351
It's the tank in front of the axle
Old 09-18-2011 | 02:07 PM
f-trucker88's Avatar
f-trucker88
could mostlikely be 19 gallons if the gauge is broken possible sending unit failure
Old 09-18-2011 | 08:34 PM
stock95's Avatar
stock95
STEEL OR PLASTIC?
IF ITS STEEL THEN ITS 18 GALLONS
IF ITS PLASTIC THEN ITS 19 GALLONS
SOUNDS LIKE A SENDING UNIT NEEDS TO BE REPLACED
HOPE THAT HELPS
Old 09-18-2011 | 10:09 PM
kelly351's Avatar
kelly351
Thank for all the help. I figured it was probably sending unit. Is there anyway to check the gauge cluster?
Old 09-18-2011 | 10:16 PM
frenchy107's Avatar
frenchy107
try swapping to the other tank to see if the gauge changes with the second tank
Duckhunter3688
1999 to 2016 Super Duty
09-15-2017 06:53 PM
nissen4
05-06-2016 04:53 PM
techmech
11-10-2007 08:53 PM
mdjohnson
12-17-2005 09:42 PM
EBronco
10-12-2004 05:53 AM
