1968 f250 power steering
Old 09-17-2011 | 03:02 PM
birddogman1's Avatar
birddogman1
just wondering, do i have to replace column for power steering cant i just replace power steering box and add a pump and keep original column
also i am looking for an axle flip kit but cant find one
any help would be great
last but not least i have the original 16" split rims on it it is 8 lug
what wheels and off of what will fit on it
thanks
Old 09-17-2011 | 03:44 PM
jowilker's Avatar
jowilker
If you use the recommended Ford Saginaw power gear you have to swap the column. The connect point is 2 1/3" towards the firewall from the other.
Split rims were still used in 68, did not know that. Any of the Ford 8 lugs should work, but test fit first before purchasing.
No help on the kit.
John
Old 09-17-2011 | 04:16 PM
birddogman1
power steering
i really know nothing about power steering i thought you could just replace old box with a power steering box and add a pump and keep column
and im not 100%sure if they are original but i know they are on there
also is there any aftermarket wheels that will fit none of the newer ford wheels look all that good
Old 09-17-2011 | 08:17 PM
jowilker's Avatar
jowilker
If you use the not recommended pos Bendix power steering you can use the existing column.
John
Old 09-17-2011 | 08:55 PM
birddogman1
power steering
So I can just use a power steering box from a newer ford and just link it up
Is that what your saying
Old 09-18-2011 | 04:43 AM
jowilker's Avatar
jowilker
Newer is the preferred Saginaw & column swap. You can also use one from a F100. The Saginaw is a much better setup.
John
Old 09-19-2011 | 01:06 AM
moonley's Avatar
moonley
I installed PS in my 1970 F250 4x4, I'm assuming yours is 4x4, and I used the box out of a 1979 F250 4x4. I kept my original steering column, but the shaft from the column to the box had to be shortened.
I would recommend that if you go this route you use a Borgeson steering shaft (you will still have to cut and shorten it) and get a redhead steering gear (reman units are all junk IMHO). But this will cost big $$
The original drag link also will need to be changed or adapted, I headed the center of mine to red hot and twisted it 90 degrees to line up...but you do this at your own risk. Mine is still too long so when I get a chance I will probably get a new one, cut it in the center, twist it, and weld a new sleeve over it (I'm a good welder).
Old 09-19-2011 | 01:09 AM
moonley's Avatar
moonley
Also, the 1979 box is not a bolt in, you will need to drill new holes and weld a plate on the inside of the frame for strength...
my truck also came with split rims, replace them asap. Any ford 8 lug will fit up until the changeover to metric with the 99 model year.
Use the search function on this forum, you'll find lots of info.
Old 09-19-2011 | 03:08 AM
94z28's Avatar
94z28
what does the pos saginaw come off of? I too have split rims on my 68
Old 09-19-2011 | 04:47 AM
jowilker's Avatar
jowilker
Hmmm, I didn't read 4X4. 4wd does not swap same as 2wd.
John
Old 09-19-2011 | 04:56 AM
94z28's Avatar
94z28
for 2x4 lol ?
Old 09-19-2011 | 07:22 AM
birddogman1
power steering
No my truck is a 2 wheel driveI'm the 3rd owner of the truck it has 94000 original miles
Its not pretty but I'm proud of it
I think I'm going with the saginaw box and cut the column
Not sure which year box to go with though.
Old 09-19-2011 | 09:05 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The steering shaft, shift tube (if so equipped) are different lengths with/without P/S.
There are two different types of P/S, the parts do not interchange. You need the column that matches the type of P/S and the year it comes from.
1966/68 F100/250 2WD, 1969 F100/250 2WD before serial number D96,001 used awful Bendix P/S.
Parts for the Bendix P/S gearbox including the seal kit are almost non existant.
1969 F100/250 2WD & F350's from serial number D96,001 used Ford (Saginaw) P/S as did 1970 and later.
This is the type of P/S you want, because it's a better unit and parts are readily available. The seal kits are the same thru 2002.
Old 09-19-2011 | 10:27 AM
birddogman1
power steering
So if I understand correctly if I use a 69 or newer
Pump and column it would work
Do I still have to cut column
Old 09-19-2011 | 11:43 AM
jowilker's Avatar
jowilker
For power steering upgrade only, any 73-79 F series 2wd will work. Find a donor truck with an engine & transmission like you have. Harvest the column, gear, pump, bracketry, hoses/lines for a swap to your truck. There may be a few more donor options but that is enough to get you started. I run a 76 column in my 66.
Many of us upgrade to power disc brakes at the same time. Get it all from the same donor, save headaches.
John
Quick Reply: 1968 f250 power steering
