I tried the nav in motion override with no results, seems to be for 2008 or older system. Is one available for a 2011 F250 Sync? I have looked at Lockpick and others, was hoping to get away with easier option.
There isn't any easier option. Lockpick is the only solution.
Oh, and if you do put a Lockpick in, be prepared for a fight with Ford to get your NAV/Sync repaired under warranty. I only mention this because there appears to be a lot problems with the 2011 F150 Sync.
In order for your passenger to change the navigation you have to stop the truck, wife is not thrilled.
Lockpick lets you change certain lockouts, ie nav, dvd in motion, rear camera...
The lockpick is an easy install, all plug and play (have it on my nav unit). If you have radio troubles, just take it out before going to the dealer...
interesting. So where does one get this "Lockpick", is it hardware or software, and how exactly does one de-install it when going for Navigation service if the dealer wont support it? How long does it take to remove?
It's a module that plugs in line with the stereo. Doesn't require any separate power/ground/etc wires (at least on my SD Nav unit). It took me longer to get my dash and the stereo out than hooking it up.
