4.9L oil leak front of engine and noise
Old 09-11-2011 | 02:36 PM
bigb609's Avatar
bigb609
I purchased 1987 4.9 L recently. I have two symptoms. One: a oil leak front of engine; which I believe is front main seal. I degreased engine and it appears to be coming from there. Second symptom is a on again off again noise that sounds like it may be bearings. At first I thought it was power steering pump. But after searching on net and reading threads I'm thinking it may be something behind timing cover or harmonic balancer. Any ideas???
Old 09-11-2011 | 10:16 PM
AbandonedBronco's Avatar
AbandonedBronco
It's possible that the harmonic balancer is going out, and that'll make some noise.
As for the oil leak in the front, about the only thing up there is the timing cover. A timing cover gasket set includes the front of the oil pan gasket (since they touch), the gasket between the cover and the block, and the front main seal around the harmonic balancer.
The whole kit (get the more expensive of the two) is about $15 - $20.
I did mine in a few hours. Takes removing the radiator and the fan, as well as a good puller for the harmonic balancer. If the balancer comes off in two pieces, you know it's bad.
Old 09-12-2011 | 08:21 AM
bigb609's Avatar
bigb609
Thanks
Thanks for the help.
bass-n-fire
1997 - 2003 F150
03-25-2017 12:50 AM
PLC1985
12-03-2009 04:48 PM
wreakshavok
04-08-2006 07:00 AM
shel 67
Aerostar
05-15-2004 01:40 PM
fatherdoug
05-30-2003 11:20 AM
