1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
F250 CC and Blinker problems
Old 08-31-2011 | 06:44 PM
yesitisrob's Avatar
yesitisrob
First let me start by saying the knowledge in this forum is awesome. Ive used it to solve many of the problems on my truck and I thank you all!
Now on to what the search button couldnt fix.
I have a 03 F250SD 4 door FX4 Century addition 5.4L automatic. Last week my cruise control, the overhead temp/compass thingy also quit displaying (the dome lights do work). Also the turn signals stopped working, however the wiper controller does work. Ive read for the last 3 days on different things.
the horn works fine (used often)
Brake lights work fine
Reverse lights have been removed to make room for strobes (just back up until i hear a bang or crunch)
I have literally gone through each and every fuse I could find and all are good.
Normally i would not have a problem with the blinkers not working, but im going out of town this weekend and the cruise control is going to be needed.
Old 08-31-2011 | 08:17 PM
Shake-N-Bake's Avatar
Shake-N-Bake
When my turn signals stopped working it turned out to be a bad Multi-Function switch. It's basically the entire turn signal stock assembly. The CC might go through that as well but I'm not sure. Do you have another truck handy where you can borrow the part for testing? It's super easy to change so it's worth trying before you actually buy a part that you might not need.
Hope you figure it out soon.
Old 09-01-2011 | 12:38 PM
yesitisrob's Avatar
yesitisrob
Sadly I do not have another truck like mine to test this with. Normally I would agree with you, but I wouldnt expect the overhead compass/temp computer to also stop working.
Old 09-01-2011 | 12:46 PM
Shake-N-Bake
Correct,
The overhead console is on a completely different harness. Actually runs the other way towards the passenger side as well. Plus your cruise isn't working and I think those wires are different than the multi function switch as well.
Do you have cab lights?
Old 09-01-2011 | 12:50 PM
yesitisrob's Avatar
yesitisrob
Yes, the cab/dome/map/courtesy reading lights are working just fine.
Old 09-08-2011 | 03:16 PM
yesitisrob's Avatar
yesitisrob
Bump, any suggestions??
Old 09-08-2011 | 10:41 PM
iamtrace's Avatar
iamtrace
I have a 2005, I do not know if yours is like mine. I was not getting a blinker on the front right, a fast blink on the right rear and no light on the dash. You could hear the clicking under the dash. I moved the turn signal stalk down just a bit but not off. The light on the dash would come on, the blinker came on in the front and the rear blinked correctly. I had to change the multi swith blinker system.
Flip420
01-31-2019 02:39 PM
NIdude
08-10-2014 07:18 AM
red Skiff 150
2004 - 2008 F150
01-21-2012 06:30 PM
yachtonwheels
Electrical Systems/Wiring
10-11-2009 02:07 PM
Mapk
01-20-2008 08:00 PM
