13 PSI Boost!!!
#31
#32
I guess I missed that part, I see a regular hit of 25psi on my 80e tune highway cruise is 3 to 5 psi on my dd tune I can hit over 35 that's with the 38 sleeve bearing waste gate eliminated, I just don't think your getting full boost, could be a IC tank blowout I have seen that before but it's pretty obvious by the oil mess it leaves along the edge of the tank seam, but it does make it impossible to build boost over a certain psi as the seal fails and compressor can't keep up, its worth a look!
Jim...& fat Monty
Jim...& fat Monty
#33
#35
i have the van turbo set up also(as we discussed) i had a few boost leaks after installing the turbo..one at the map line where it goes to the spider and one boot. fixed those and got 25 the other day...just fixed collector and hopefully ill get more...in 80e also. i have my gauge directly into the AIH delete plug though. not sure if that makes a difference. maybe check the fitting for the boost gauge. seems way to low to take the truck sideways too...just me .02$
#36
Jakeman68
13
01-01-2007 05:22 PM
