Installing lift kit
Installing lift kit
hey guys so I bought a 4 inch bds lift but I wasnt able to get a shop to do it until next week and I want it in before the weekend. So now a friend of mine and I are installing it on friday. Is there anything I should be concerned about or any tips any of you guys have would be greatly appretiated thanks i will be sure to post up some pictures when its all set and done.
Have tall jack stands and jack. Those front springs can be long so you need to get the truck high in the front end. Also get a good pitman arm puller. Those things can be hard to get off. A inpact gun and wrench helps out a lot. Are you doing block with add-a-leaf in the rear or new springs?
Well just installed lift on jeep awhile back and if you have high arched leafs they can be a bitch. Bolt up non shackle end first then you have to jack them in place. We found that the lift leafs were 3"s shorter than the stock ones, so you have to flatten them out to make them longer. JMO
It might look scary as sheoit, but jack stands behind the radius arm mounts on the fame will keep the front end off the ground so you can drop the axle and the arms without anything in the way. To make the stands taller I built cribs from 3 layers of crossed 2x4s sandwhiched between 1/4 plywood, worked great. To get the truck high enough I used floor jacks under the radius arm mounts on the axle to make enough space to put fully screwed out bottle jacks on cribs.
Pull the brake calipers and tie downs for the brake lines early and tie them out of the way.
TheBlueMule
05-03-2009 08:17 PM
supercab4x4dually
19
09-06-2004 03:44 PM
TrueBlueV10
1999 to 2016 Super Duty
08-05-2003 07:39 AM
jscoggins18
11-19-2002 07:56 AM
