275/70/18 on a 2wd
275/70/18 on a 2wd
Okay so my buddy has a 2007 F-150 2wd, no leveling kit. He is currently running a 275/65/18 on stock 18 inch rims with no problems but wondered if he could fit a 275/70/18 under there with no rubbing or problems? I think they are only about and inch bigger, but he didn't want to order the tires then end up with a mess. I figured I would ask around and see what I could find out. The main reason he is looking at the larger size is for some reason the BFG All Terrains are cheaper in the larger size.
Thanks,
Kevin
Thanks,
Kevin
j.white36
02-02-2016 10:36 AM
